2007 F150 Lariat 5.4L Multiple codes
I have a 2007 F150 Lariat with the 5.4L Triton V8
151,000 miles on it.
Started misfiring, chugging, dieseling, etc. Check engine light came on. Checked codes and found the following:
Active Codes
P0012 Camsaft Position Actuator A - Bank 1 Timing over retard
P0016 Cam/Crankshaft Pos. Correlation Sensor A - Bank 1
Pending Codes (1-5)
P0022 Camsaft Position Actuator A - Bank 2 Timing over retard
P0300 Random/Multiple Cylinder Misfire Detected
P0303 Cylinder 3 Misfire Detected
I've done some research and haven't found anyone posting all these codes together. Found some P0012 postings and some P0016 postings. Before I tear into this engine and start spending money I'm looking for someone that's experienced these codes together.....
Any guidance appreciated!
Active Codes
Pending Codes (1-5)
Your codes are indicating phasor circuit failure of course you will have misfires
Phasors are hydraulically operated using dirty engine oil , PCM sends electric pulse to VCT solenoids releasing engine oil to phasors . Cam sensors tell position or lack there of . Crank position sensor is compared to cam position and what PCM has called for .
Trouble is filter screens in vcts and other small passages get clogged with combustion carbon in oil . This circuit needs around 20 psi oil pressure . gauge on dash-- junk reads center for anything over 7psi .
plastic Tensioner seals blow out and dump oil pressure starving cam and phasor circuit . Loss of oil pressure loses tension on chains they whip and break plastic chain guides . Pieces fall in to oil pan and clog oil pickup causing lower oil pressure . Chains start eating aluminum timing cover and jump time . Phasors go bad lack of oil .Don't use aftermarket .
The fix is old style ratcheting metal 2v tensioners with no seal to blow out . Amazon and melling have them new . New updated VCTS , new OEM updated phasors . New lash adjusters and rollers and a new oil pump melling 340 or 360 .
Use only syn oil ,no extended oil change, use mc filter with good drain back check valve . No one makes better plastic guides that break . Pre fill oil filter before putting it on .
When you do timing job clean everthing including vcts bodies .
The following users liked this post:
Active Codes
Pending Codes (1-5)
Active Codes
Pending Codes (1-5)
BDog1971
2004 - 2008 F150
10-03-2017 07:25 AM
