Need help!! Code P0106
Old Apr 16, 2009 | 11:32 PM
badazzharley's Avatar
badazzharley
My son's '06 F150 is running rough, won't idle smoothly and is throwing code P0106. I changed out the MAP sensor but it didn't help. What else could be causing the code?
Old Apr 23, 2009 | 01:35 PM
shadetreetn's Avatar
shadetreetn
did you get an answer? I changed the fuel filter and that didn't work.
Old Apr 23, 2009 | 06:30 PM
FTE Trigger's Avatar
FTE Trigger
Did you clear the code and it returned?
Old Apr 23, 2009 | 06:41 PM
shadetreetn
Yes it did. My next step is to remove the intake manifold and see if there is something stuck in there.
Old Apr 23, 2009 | 08:19 PM
Supercrewzin01's Avatar
Supercrewzin01
Did you get the code read? How many miles are on the truck?
Old Apr 28, 2009 | 02:36 PM
shadetreetn
97,000. I've checked for vacuum leaks. Can't find any.
Old Apr 28, 2009 | 05:05 PM
Supercrewzin01
Check your IAC valve, they usually go out around 80,000 miles. You can take it off and try and clean it out with a q-tip and see if that helps. If not, you need a new one.
Old Apr 28, 2009 | 09:31 PM
shadetreetn
I'm having a hard time finding where the IAC valve is located.
Old Apr 29, 2009 | 05:57 PM
Supercrewzin01
On a 4.6 it is on top of the engine, and on the 5.4 it is on top of the engine right next to the firewall. There are 2 bolts that need to be taken off along with a plug that needs to be disconnected.
Old May 1, 2009 | 01:13 PM
shadetreetn
Is the TP sensor attached to it?
Old May 1, 2009 | 08:32 PM
Supercrewzin01
I will try and take a picture of the one on my 5.4 and show you what it looks like tomorrow.
Ralphf250
6.7L Power Stroke Diesel
18
Feb 19, 2021 05:47 PM
schism1861
2004 - 2008 F150
Nov 22, 2020 03:36 PM
rolo923
Escape & Escape Hybrid
Mar 2, 2017 06:25 PM
antwan181
21
Sep 14, 2016 05:11 AM
Ron Purpura
2004 - 2008 F150
Mar 12, 2013 07:50 AM
