Rough idle w many codes
Old Apr 2, 2017 | 05:54 PM
Tile man's Avatar
Tile man
i'm new here and not sure if i'm doing this right but I just recieved a 06 F150xl with a 5.4 triton and idles rough with the following codes PLEASE HELP! p0357 p0012 p0340 p0344 p0351 p0352 p0356 p0358 p0357 p0102 p0113 p0353 p0354 p0355 It's amazing the truck even runs and with no light on but it will accelerate. someone mentioned to clear the codes and drive it 50miles or so and read them again. Tanks
Old Apr 3, 2017 | 09:37 AM
alloro's Avatar
alloro
Inspect the wiring in the engine compartment for signs of animal chewing on it.
Old Apr 3, 2017 | 12:56 PM
steve(ill)'s Avatar
steve(ill)
several of the codes are related to the wires/ plugs going to the coils on the plugs. Look for wires pulled off the COPS, burnt, or as mentioned squirrel/ mice eating wires ........ specifically around the coils.
Old Apr 3, 2017 | 05:25 PM
Tile man's Avatar
Tile man
Thank you very much, I just got the truck cheap. It was a service truck for a company that went belly up and it was sitting for a year, so that makes sense. i didn't see any evidence of mice but that doesn't mean there weren't any. When I changed the plugs I broke one clips off the cop connectors and another wont lock. I also noticed that the rubber seals inside some of the connectors are ripped or gone. One had looked to been replace (professionally). I'm gonna replace the remaining ones. What is the best thing to clean the contacts on the cop end? and should I be using Dialectic grease?
Idk if I mentioned that many of the coil codes were repeated in the reading. Someone told me to clear the codes, so I did and am going to recheck tomorrow. Thank You all so much, I will keep you posted.
Old Apr 3, 2017 | 06:52 PM
steve(ill)'s Avatar
steve(ill)
yes, you could have a couple bad COP electric plugs and get several of those codes. I have bought new socket with 6 inch wire leads off e-bay to replace if needed. If they don't lock or don't have seals, then they are probably shorting out and giving codes. Clear the codes, or pull cable off battery for a couple minutes, then reinstall... codes go away... most will come back if you don't fix the plugs.
Old Apr 3, 2017 | 09:24 PM
Tile man's Avatar
Tile man
Thanks Steve,
I ordered new plugs on Ebay and will solder and shrink tube them, should I use dialetric grease on them as well?
Old Apr 3, 2017 | 10:05 PM
steve(ill)'s Avatar
steve(ill)
I prefer to use a spray contact cleaner that evaporates and leaves no residue, then push together dry........ I had one COP that continued to give codes after replacement and I traced it to EXTRA di-lube on the boot to spark plug connection... after that I use VERY LITTLE on the sparkplug boot and nothing on the elect plugs.
--if you have any dust, dirt, water, etc inside the plug you risk a short and getting a code... that's why I use contact cleaner prior to assembly.......... dialect grease is great for tail lights and such.
Old Apr 8, 2017 | 02:31 PM
Tile man's Avatar
Tile man
I really want to thank you gentlemen for your expertise.
I changed all the COP connectors and cleaned the COP terminals with contact cleaner. They looked pretty rough as you can see in the photo. I don't know if polarity matters but I noticed all the clips had a red wire on the same terminal except for the #6 clip which was changed once before, so when I changed it I put the red on the same terminal as the rest. The truck runs a lot better with no backfiring. Shifts and
accelerates fine now.
With all that being said I still have a rough idle and a few codes still. The codes are P0012, P0340, P0344
Old Apr 9, 2017 | 08:30 AM
steve(ill)'s Avatar
steve(ill)
on any truck with a "sensor" problem, the first thing to do is check the sensor plug, the wire condition, and suspect the sensor if the above is all good....... Since you have a "post 2004" motor, they are also known to have additional cam phaser problems that might effect this ?........... to start , I would check the wires / plug / sensor .. similar to your spark plug problem.
Old Apr 18, 2017 | 08:51 PM
Tile man's Avatar
Tile man
So after I changed all the cop connectors I narrowed it down to the last 3 codes I listed then after driving the truck for a week it died out at the end of my street. It looked to be the fuel pump but with the expertise of my neighbor, he told me to check the Fuel Pump Control Module bolted to the frame on top of the spare tire. When I pulled it down it was just as he suspected, The aluminum had corroded and it had a 2' hole in it. I replaced that and found the connector is bad also. Well when I straightened all that out, I also got rid of 2 codes. Now I only have a P0012, my neighbor seems to think its the #1 fuel injector. We'll see... To be continued
eallanboggs
1997 - 2003 F150
Oct 30, 2018 10:29 PM
gassplant
2004 - 2008 F150
Jan 25, 2014 01:01 PM
jhayden
2004 - 2008 F150
Jun 7, 2012 09:19 PM
xlttruck
Modular V8 (4.6L, 5.4L)
Jul 9, 2007 06:58 PM
nyrockingchair
1997 - 2003 F150
Apr 12, 2006 08:15 AM
