Help needed
Old Oct 3, 2016 | 01:03 PM
Jonathan Day's Avatar
Jonathan Day
Help needed
I have a 2007 Ford F-150 5.4l v8
Codes
P0012 int cam position timing over ret bank 1
P0022 int cam position timing over ret bank 2
P0300 random Missfire detected
P0316 engine misfire detected on start up
P0340 cam position sensor curcuit fault
P0345 cmp sensor a circuit problem bank 2
Starts rough, idles rough and stalls occur often when start, after it runs for 5 minutes and sometimes dint starts at all. I replaced spark plugs, coils, cam shaft sensors and had oil changes done and. No effect.
Old Oct 3, 2016 | 01:04 PM
Jonathan Day
The codes started Up after the codes for the cam shaft position sensor faults.
Old Oct 3, 2016 | 01:31 PM
EBC-150's Avatar
EBC-150
Try unplugging the VCT solenoids and see if it smooths out.
Old Oct 3, 2016 | 02:50 PM
Jonathan Day
Where are those located
Old Oct 3, 2016 | 03:02 PM
Jonathan Day
Found them and she started and the idle was really rough and she was ticking like crazy
70f100longbed's Avatar
70f100longbed
Check the crankshaft endplay. Ford had a problem with the 2007s thrust bearings causing the crankshaft to walk back and forth.
Old Oct 3, 2016 | 03:04 PM
Jonathan Day
How would I do that?
Old Oct 3, 2016 | 04:04 PM
EBC-150's Avatar
EBC-150
If it's running worse, then I would be looking into timing/phasers. Broken chain guides and loose chains can cause the valve timing to be off more than the phasers can compensate for. Your codes state that the cam timing is off and it will misfire if it is.
Old Oct 3, 2016 | 04:06 PM
EBC-150's Avatar
EBC-150
Mount a dial indicator on the end of the crank and pry the crank/pulley back and forth...
jrbubachmech98
2004 - 2008 F150
72
Nov 17, 2022 01:13 PM
DocTrevena
1997 - 2003 F150
Feb 12, 2012 04:20 PM
b69bama69
1983 - 2012 Ranger & B-Series
Jan 6, 2007 08:05 AM
tastefulasever
Sep 4, 2004 09:45 PM
T BLAUVELT
Jun 17, 2003 03:33 PM
