I have several lights out and I've decided to replace them. I've got my haynes out and it makes it seem like a lot more work than I imagined. Is there an easy way to remove?
1 remove the 3 screws along the op if the I/C trim panel(screw into the bottom of the dash pad)
2 remove thee Headlight and wiper *****.( there is a little notch where the rod goes into the ****,if you spin the ****, you will seeit. Take a 90* pick or small screwdriver and get in the slot, and push in the back of the **** while pulling on the ****.)
3 I/C trim panel is loose. Pull out ward on the top. Once past the dash pad pull upward. Then pull loose any a/c air hoses. And twist off of Steering column.
4 if you have an auto. Remove trim around the column. Yoy will see a mall white plastic cable held on w a screw. Remove the screw, but kppe track where the cable was located .take the loop of the cable off the pin.
5 remove 4 screws holding cI/C to dash. Pull out as far as you can, disconect any electrical plugs and "squeeze the white ring on the speed cable to disconnect it.
Install is reverse of removal. I WOULD CHANGE ALL THE BLUBS WHILE IN THERE
The blue covers should just pull off. The bulbs just simply twist out of area. If you take the blue covers off your lights wont be colored anymore, but at night your visiblity will be alot better. Yes just replace the bulbs.
