300I6 Powered
Old Jul 10, 2009 | 01:35 PM
  #91
91Bronc300's Avatar
91Bronc300
It was mostly just the pathetic cam and then retarding it 4 degrees from factory that made the 400 such a pig. 175 HP and 325 TQ. But it's incredibly easy from what I've read to unleash the potential of that engine. A better cam with a straight up sprocket, very minor head work, a small bump in compression. And you get over 300 HP and TQ around 450. But I already have the 300 performance parts, and the bellhousing and things I need to do the swap. Plus I don't want 400 CID mileage. The only thing I would miss by doing the swap is the exhaust sound.
Old Jul 10, 2009 | 01:39 PM
  #92
91Bronc300's Avatar
91Bronc300
Originally Posted by AbandonedBronco
This is true if the stock EFI injectors were to flow as much fuel as a 4bbl, which I don't believe they do. Then, they're tuned with emissions in mind, not horsepower.
I imagine a different computer with even the same injectors could be tuned for way more power. The stock exhaust on the EFI was 2" IIRC. 25hp/30tq over stock EFI from a power tuned computer doesn't seem like that much at all.
Then, you've got a 1bbl carb motor that's way restricted. 50 horsepower from removing a restrictive intake and exhaust and then well over doubling the fuel input, and allowing it to rev another 1000RPMs. Dunno, seems reasonable to me.
I think if I was estimating 250hp or something ludicrous, that'd be up for big debate, but getting 175hp out of a 300ci engine with a full intake, exhaust, and fuel system upgrade doesn't seem like a stretch.
Again though, just estimations.
*Does my best Batman impression*
TO THE DYNO CAVE!!
oh wait, I don't have one
Old Jul 10, 2009 | 02:13 PM
  #93
70torino429's Avatar
70torino429
Ford's exhausts are horribly restrictive, it goes down to extremely small piping in some places. With a cam to accompany the exhaust and headers i can see a 50hp gain being realistic, not sure if exhaust alone could do it.
And yes, the 400's can be built up to make lots of torque and power, they just came out in a smog era, so they have a horrible reputation. If they had been released in the 60s when high output motors were the hot ticket, i bet it would be a whole different story.
Dynos are useless.
Old Jul 10, 2009 | 04:10 PM
  #94
6CylBill's Avatar
6CylBill
You guys would probably know more than I do. My knowledge is all gained from driving my truck and from the knowledge other users have put on this website. I still say you're over estimating, but who cares? I hope you do have 175 / 290! I just can't see it.
Old Jul 10, 2009 | 04:24 PM
  #95
91Bronc300's Avatar
91Bronc300
Originally Posted by 70torino429
Dynos are useless.
That's like a carpenter saying 'measuring tapes are useless'
I'm with you Bill. 50 HP sounds a little high for a 300 with a stock head, even with a 4V carb and intake and better exhaust. But also, 30 ft/lbs sounds even a little low for what he's done. I bet Abandoned has gained more torque and less HP than what he's estimating. And that carbed engine is a pretty different animal than the EFI. Even though the engine underneath is basically the same. Because the carbed is not constrained by injector flow rates and computer management and everything else. You can basically bolt it on, tune it up, and go with a carbed motor and see all the benefits. With EFI you have to do a lot more. Even more so with the 300 where injectors, sensors, computer, are not capable by design of supporting much more power than stock. That's why people do EFI to carb conversions on these engines.
Old Jul 10, 2009 | 04:45 PM
  #96
6CylBill's Avatar
6CylBill
Torque is what makes a truck accelerate and pull so it's easy to over estimate actual horsepower. I agree with you.
I think when you're dealing with such relatively low numbers (in my case, not much over 100 horse at the rear wheels) small improvments can feel big (exhaust for instance). You're not going to feel ten horse to a one thousand horsepower V-10. You'll feel ten horse to a one hundred horse pick'em-up truck, though.
Am I making any sense?
Old Jul 10, 2009 | 04:51 PM
  #97
70torino429
seeing as there are so many different types of dynos (Super Flow (901 or a 902)
-Stutska, DTS, and mustang dynos ar the most commonly known) that will all show different readouts, so you trying to tell me they are accurate? i could write paragraphs and paragraphs about this, but i dont think you would really understand it.
Dynos are great for getting a rough tune i suppose to get you close to what your looking for, but the real dyno, is REAL WORLD DRIVING in ACTUAL driving conditions, not strapping down to some rollers in a climate controlled room with a fan blowing through your radiator.
i know for a fact someone who lost about 15hp and 25 ft lbs on the lovely dyno, yet picked up .3 and 4 or 5 mph in the 1/4 mile . you want to explain that? The guy that ran the dyno shop himself couldn't explain it, so i dont expect you to either. I dont feel like arguing over a proven point, i can lead you to some websites with people that will laugh at you. street tuning, and race track data are all you need for tuning, dynos are pointless, and if you had setup a few 1/4 mile cars you would know that. I dont race dynos, no one i know does either.
Actually, heres a little statement from the owner of camshaft innovations (Jay allen) regarding chassis dynos, who designs custom camshafts.
I took a stone stock short block with GT-40 heads. Like an idiot I kept it EFI. I wanted to see just how fast I could go with a stock short block and unported GT-40's. This is well documented on other sites.
The baseline on the car was 12.30's. Typical STD junk.
But here is how I tuned it. I have what is called a RacePak. It is what we use in race cars to measure clutch slippage primarily. Clutch slippage is VERY useful in race cars and I also had a clutch (eventually) that I used in this POS too.
But I went out on the back roads here in SE Michigan. I would make several hits, go home and down load them. I was looking for the time spent in each gear and usable RPM. I could care LESS how much power I made. If I made a change that made the car "quicker" then that was a positive step. I made MANY dozens of changes that folks say "make power", fellas you might as well buy one of those Tornado do-dads! LOL
In the midst of all of thus, a "new breed" ~dyno~ kid want to be me that my car was making 330 RWHP as I just ran it at Milan Dragway. I went 11.50's if I remember correctly. I am old and this was 3 years ago. I told him I would be LUCKY if it made 300 RWHP.
FYI. The car weighed 3190 - 3210 depending upon the fuel.
So I attended this "dyno day"! Woo-Hoo! LOL I pulled the car up and we made 2 hits. It made 305 RWHP. Then here it come.......
-You are too rich. The A/F is way off.
-Your timing is locked out.
-The plugs are too hot.
All I could do was laugh.
So I sat down and told them to have at it. Tune the old girl up!
They removed my old school Extender. They sat the base timing at 10* and made up so hokey curve. Played with A/F so it read "12.5:1, gotta have 12.5:1".
It made right at 320 RWHP.
They were so excited.
That night I took the "dyno operator" out with me for some late night blasts. I made 2 hits and data logged them just the way he had it. He was impressed how smooth the junk pulled to 6500 RPM. I laughed. I told him it was so lean and that the timing curve was *****ed up. All I got was "the dyno said".......
I put it right back where I had it.
I pulled the spout, set total at 36*.
I set the base fuel pressure at 47#, vacuum line off.
I unplugged the chip and reinstalled my Extender.
I told him to hang on.
That POS would rev to 7500 RPM it would make your head spin. He was scared to death.
Now the good part.......
From 3500 RPM in second gear to 7200 RPM in 4th gear, the car was a FULL 2 seconds FASTER with dyno verified less power.
Seeing is believing.
Do Not race a chassis dyno.
The pile ended up going 11.19 at 119.
Like i said, dynos are useless.
Old Jul 10, 2009 | 04:54 PM
  #98
70torino429
If all that is too much for you to swallow 91bronc300, feel free to pm me and i can try to explain it to you. If that isnt enough to show how dynos are useless then i dont know what is
Old Jul 10, 2009 | 05:01 PM
  #99
AbandonedBronco's Avatar
AbandonedBronco
True, true. However, horsepower is calculated directly from torque, so you can't increase one without the other, as long as its at the same RPM. Lets say the torque peaks out at 290/300 or so. Since it breaths so much better, I can easily rev to 4500 without thinking twice (usually never over 4000 just for safety sake on the engine). But lets say it's a relatively flat torque curve and starts to drop, and by 3500RPMs, I'm down to about 260tq from the 290. Just a couple different random figures to show a "ballpark" of where the torque could be at high RPMs.
Stock
(214tq * 3000) / 5252 = 122hp carb
(223tq * 3400) / 5252 = 145hp EFI
Modded with major increases in in/out breathing and nearly double the fuel delivery (~190cfm to 390cfm).
(260tq * 3500) / 5252 = 173hp
(250tq * 3500) / 5252 = 166hp
(240tq * 4000) / 5252 = 182hp
(240tq * 3500) / 5252 = 160hp
Again, this is purely subjective depending on when the torque drops off, etc. However, it's one thing to take an already powerful engine and boost it further (that gets difficult). It's another to take a big engine that's completely restricted, remove the restrictions, and then boost it up. You're overcoming it's shortcomings, and then adding more.
Not saying I HAVE 175hp, just saying how I calculate that it could have that much, and why it'd make sense.
Old Jul 10, 2009 | 05:09 PM
  #100
91Bronc300's Avatar
91Bronc300
A lot of people would tend to disagree about a dyno being useless. I know I would still take one.
Not knocking your opinion at all.
Old Jul 10, 2009 | 05:11 PM
  #101
AbandonedBronco
I would say that dyno tuning may be what's subjective. But just putting your vehicle on a dyno to see what numbers your putting down would not.
Old Jul 10, 2009 | 05:19 PM
  #102
70torino429
Nothing against putting your vehicle on a dyno just to see what its making for curiousity, the dyno tuning part however....isnt really worth the money. youd be better off tuning on the street or track, you dont need to drive 100 mph to do tuning, so its fine for the street, you just need to run through the entire rpm range and then tune accordingly. Thats how i tune all my stuff. Just my .02/
Old Jul 10, 2009 | 05:22 PM
  #103
lew52's Avatar
lew52
....Thats just IGNORANT !!! Thats all i have to say... Lew
Old Jul 10, 2009 | 05:30 PM
  #104
91Bronc300's Avatar
91Bronc300
I know that if you look at a dyno graph the HP and TQ always intersect at 5252 RPM because that's dictated by the conversion formula.
But doesn't that mean (correct me if I'm wrong, I may be, I'm only hypothesizing) that any increase in torque below 5252 has to have a corresponding SMALLER increase in HP and any increase in torque above 5252 has to have a corresponding LARGER increase in HP?
Say for example you add 10 ft/lbs at 2000 RPM that's an increase of 3.8 HP. If you add 10 ft/lbs at 3500 RPM that's 6.6 HP. Add 10 ft/lbs at 5252 RPM and you add 10 HP. Add 10 ft/lbs at 6000 RPM and you add 11.4 HP and if you add 10 ft/lbs at 9000 RPM you add 17.1 HP.
So under 5252 RPM isn't it impossible to add more HP than you do TQ? (at any given point anyway, not averaging the whole curve). And anywhere over 5252 RPM it's impossible to add more TQ than you do HP? Just a hypothesis.
So adding 50 tq and 30 hp is more likely for a low revver like a 300
Old Jul 10, 2009 | 05:33 PM
  #105
70torino429
Then why dont you head over on to sbftech.com, and talk to the master himself, Jay allen? because he will laugh at you, and so will everyone else over there, because they are experienced engine builders.
Maybe i should just stay out of the engine sections of this site, or just leave this site altogether, since all the misinformation is making me sick sometimes.
