ccv mod
Old Jun 9, 2009 | 08:57 PM
73pwrstrk's Avatar
73pwrstrk
ccv mod
does any one have any pics of an install on this mod?
Old Jun 9, 2009 | 09:47 PM
kawa's Avatar
kawa
I don't have pix but it is so easy a dysfunctional monkey can do it. I did it.
Take the two (2) screws out of the "Dog House" and turn it around so the 90* is towards the fire wall. The O-rings beneath it will probably be shot so just find some that will fit at a hardware or parts store.
Take a length of 3/4" hose (get enough so that the end will be well behind the cab.) connect it to the 90* and run it UP AND OVER the power brake unit then down and under neath the truck. Running it over the brake unit allows vapor mist to run back into the engine.
Run the hose along the frame making certain that it does not droop as fluid will/may collect there and shut off the breather effect..
Now where the original hose was connected to the intake tube, block that off, I cut a plate out of thin metal, drilled a hole for the original screws, applied RTV and plugged the hole.
Some have made some type of a breathe/filter for the end of the hose. I have one on mine and I have never collected enough fluid to worry about.
Viola.....CCV mod finished.
Rog
Old Jun 9, 2009 | 09:49 PM
crzycrazycarl's Avatar
crzycrazycarl
what are the advantages to this mod?
Old Jun 9, 2009 | 10:42 PM
73pwrstrk's Avatar
73pwrstrk
hey thanks alot sound like a quick little thing to go ahead and do over the weekend.
Old Jun 9, 2009 | 10:52 PM
kawa's Avatar
kawa
It keeps the oily mist out of turbo and connecting air hose.
Rog
Old Jun 10, 2009 | 06:25 AM
Cuda_jim's Avatar
Cuda_jim
You only need this mod if you have an intercooler IMHO. It keeps the oil from the blowby out of it. Also, the rubber boots may blow off due to the oil too. There may be a performance gain if you route it into the exhaust.....CORRECTLY. If it's done wrong you may blow the dipstick right out of it's tube and cause engine oil leaks.
I have installed many on gassers with as much as 30HP increase...on a dyno. Never dynoed a diesel to see if there are any gains.
Look here, scroll down for the pictures I posted:
https://www.ford-trucks.com/forums/5...ccv-flack.html
Old Jun 10, 2009 | 03:36 PM
c00nhunterjoe's Avatar
c00nhunterjoe
Old Jun 10, 2009 | 03:37 PM
c00nhunterjoe
....double posted for some reason.......
Old Jun 10, 2009 | 05:04 PM
73pwrstrk's Avatar
73pwrstrk
thanks for the pics joe. rog wasnt kidding a disfunctional monkey really could do this...haha
harley4jcs
Jan 6, 2025 01:38 AM
dawgs150
Delaware Chapter
36
Feb 3, 2008 09:47 PM
WALJON
Oct 21, 2007 04:05 PM
mike02ss
Mar 6, 2007 08:46 AM
Rockwell
Jan 3, 2003 09:16 PM
