Dirt Cheap Backup Camera
Old Jun 8, 2009 | 11:23 PM
  #151
Stewart_H's Avatar
Stewart_H
Originally Posted by AlaskanEx
allrighty, i have mine all mounted and was using it. then i wahed my truck and now my camera is full of water its just a white blur. i would have thought the camera would have been more water tight! i was just using the garden hose and did not put direct water on the camera..yet its full of water.
i'm going to go out with a hair dryer tomarrow if its not dry and se what i can do.
Hmmm, that's good to know. I'll have to give my set up the once over to see if it can be sealed up better with some silicone sealant.
Stewart
Old Jun 9, 2009 | 07:18 AM
  #152
gr8scott72's Avatar
gr8scott72
I washed mine already and it didn't hold any water. Some must be sealed better than others.
Old Jun 9, 2009 | 08:23 AM
  #153
X-70STANG-F150's Avatar
X-70STANG-F150
Am I understanding correctly? The connection between the camera and the monitor is wireless? do you need a power source for the camera or is that battery powered? I see the package says it's great for RV's, what is the range between the camera and monitor? I just wondered if it would work as an extra rearview mirror when towing the camper.
Old Jun 9, 2009 | 08:46 AM
  #154
VaSheriff's Avatar
VaSheriff
Check the warranty instructions in the package. I would imagine Peak would replace the camera portion. And I can send you a copy of the receipt if you need it.
Old Jun 9, 2009 | 08:49 AM
  #155
bcrewcaptain's Avatar
bcrewcaptain
check the camera where the cable runs into it, on one of the ones I have the halves of the camera were pinching the cable and not sealing it 100% if that had been mounted with the cable running up I would have had same issue, I ended up taking halves apart anyway and running a bead around them to be on safe side, no issues!
Old Jun 9, 2009 | 08:51 AM
  #156
cbradford's Avatar
cbradford
Sometimes the saying is true, you get what you pay for.
  #157
bcrewcaptain
same theory I had with mine....with my pop up I can mount the camera to rear of camper, with the "transmitter/antenna" portion mounted up front inside the pop up (has enough cable to reach).
I cannot do this with the travel trailer I'm restoring however, and am extending the wires now to see how that works out.
Old Jun 9, 2009 | 08:53 AM
  #158
bcrewcaptain
*shrug*
depends what you expect, the picture quality and angle of viewing are better than the $450 sony I had on my RV, and that didn't have a 2nd AV input or audio...
Old Jun 9, 2009 | 09:20 AM
  #159
X-70STANG-F150
so, it sounds like there is a transmitter that is wired to the camera that needs a power source. this transmits wirelessly directly to the monitor which plugs into a cigarette lighter. there is no seperate receiver to hook up. does this sound about right?
Old Jun 9, 2009 | 09:23 AM
  #160
VaSheriff's Avatar
VaSheriff
I'm sorry you feel that way. These are excellent quality systems.
Originally Posted by bcrewcaptain
*shrug*
I went to my garage this morning and did a temporary install after seeing the images posted yesterday. The picture quality on these Peak cameras is better or equal to the factory installed cameras in new Suburbans.
But anyhow, I am glad the subject came up about the wet camera. Considering it takes a minimum of an hour to properly hand wash an Excursion, I don't think I would hesitate to spend an extra 60 seconds to remove two license plate screws and lay the camera inside the barn doors while I wash an Excursion. And another extra 60 seconds to screw the camera back onto the license plate.
Old Jun 9, 2009 | 09:26 AM
  #161
VaSheriff's Avatar
VaSheriff
Correct. I plugged the rear camera into an auxiliary DC outlet behind the right rear tire well.on my Excursion. And of course the LCD screen then plugs into a DC outlet up front. It's completely wireless between the rear camera and the front LCD monitor.
Old Jun 9, 2009 | 09:56 AM
  #162
X-70STANG-F150
so, for the trial rv hookup you could could plug the monitor in up front and then take the transmitter/camera setup with a seperate 12v battery to see how far away you can get from the monitor. there could be more/less interference while driving, so you would want to make sure the signal seemed pretty strong and maybe do the tests with the engine running.
Old Jun 9, 2009 | 09:57 AM
  #163
cbradford's Avatar
cbradford
So then you also remove the camera when driving in the rain?
Old Jun 9, 2009 | 10:02 AM
  #164
bcrewcaptain
yup, I as a test mounted the monitor over the windshield mirror, and was able to get roughly 10ft from the back bumper before the signal started dropping enough for it to be unusable, but results may vary when driving due to all the other interference, this the reason I will be extending the cables from the antenna to get the transmitter portion as close as possible to rear of the truck
Old Jun 9, 2009 | 10:10 AM
  #165
VaSheriff's Avatar
VaSheriff
Rain and a high pressure water hose aren't the same thing.
