Sponsored by: Real Truck
HID headlights
Old Mar 23, 2017 | 09:08 AM
  #211
JohnnyAirtime's Avatar
JohnnyAirtime
Originally Posted by thegorilla
What specification diodes do you use?
I didn't think about that for such high current. I use diodes to make my halos into turn signals on my BMW when the parking lights are off, but I use all relays for high+low on all my vehicles.
I agree: Morimoto Mini H1 are amazing!
I don't... I ordered them in a bulk package, and since have removed the package and dumped them into a container. I do know, they are big... about the size of a thumbnail long and a bit larger around then a pencil eraser. I'd assume a 10amp or 15amp sized axial diode. When I get time, I'll run out to the shop and look to see if it's stamped on the diode itself. (I just moved, and am building the shop... so, everything is still mostly boxed up).
35W HID isn't "high current". At most, it's a 7amp draw at startup which settles down to about a 4-5amp. The high current is from ballast to bulb, which your not tying into.
... in fact, on one install I stuffed the diode and light socket into a container just a tad bigger then a 35mm film container. Since your normally only using one side of the OEM socket (drivers for example) to connect the HID harness, you use the other socket for the diode (passenger side, in this example). Easy peasy.
For the projector(s)... On my Excursion, I used a Hella E55 projector. Not the easiest install, but doable. I now use the H1 since it's so much smaller, easier bulb to obtain, and installs/aligns easier. On my Tundra H1, and all the 7" round (Jeep) lights H1 as well.
Old Mar 23, 2017 | 05:02 PM
  #212
Yahiko's Avatar
Yahiko
Amperage goes down as voltage goes up.
The ballast puts out about 90 volts with
a 10 to 15 KV kicker to start the lamp.
It could be less running voltage. I have not
checked to see with the automotive HIDs.
You should be safe using a diode that is 1.5 X
the current of both lamps added together. That or
just use a 15 Amp rectifier diode.
Old Apr 11, 2017 | 05:42 PM
  #213
countrycar's Avatar
countrycar
I'm glad to help!
After our conversation, I went ahead and ordered an HID kit from Morimoto to replace the one I already had in place. After installing the kit, I checked my lights and the low beams now stay on when I turn on the Hi beams. So no need for any further wiring was needed. What a great high quality HID kit they sell. It looks to be with all there stuff to. I had already bought the Jeg's Diodes to jumper my wiring to allow me to run my low's with Hi's, but again the Morimoto kit did it. I almost bought the wire harness you had suggested to me from Amazon, but the more I thought about it, the more it nagged at me that there had to be an easier way. And after a conversation with Brad (The Brad ) on FTE he mentioned to me that the Diode method would work for me, because I had separate Lo & Hi beams lenses. Anyhow, just wanted to catch yah up on how things had all worked out, and how well my lights work now with the new Morimoto Kit installed.
Thanks again.
Old Apr 11, 2017 | 08:18 PM
  #214
thegorilla's Avatar
thegorilla
Thanks again.
Awesome! That is good to know that the Morimoto kit will do low+high out of the box. Looks like you've got some great lights now.
Old May 19, 2017 | 02:21 PM
  #215
thegorilla's Avatar
thegorilla
Originally Posted by LaxPlaya21
I just installed my HID projector retrofit last night with great results. It took a little time lining things up, but I am pretty happy now.
Black Flame Customs did an awesome job with them.
Those look great, as well as the light output! Which projectors did you have installed?
Tank2009
2009 - 2014 F150
Dec 9, 2016 01:44 PM
TexanDeepSteelBlue
Nov 6, 2016 07:44 AM
qwertypert
Sep 3, 2016 03:39 AM
Ezalycasaid
2004 - 2008 F150
Feb 27, 2016 03:08 PM
NCMODELA
Feb 23, 2016 01:19 PM
