Sponsored by: Real Truck
Spark plug blowouts
Old May 17, 2017 | 04:33 PM
Super DutyDave's Avatar
Super DutyDave
Spark plug blowouts
About a week ago i was loaded up in my 5.4l v8 f250 extended cab with 2 kids and three friends heading to the beach and i was going 70 the whole way untill dude said to pass the prius i was like alright lets do it! So then the COP and spark plug blew out and it was just making a putting noise...
(Rant)Ive bought 3 re-thread heilicoil sets 2 from autozone and one from oreily because the first one had a big handle so wouldnt fit in the cylender and the second one the tang came off so i didnt use it, wish i woulda..
So now today shes sitting there with a tap stripped out in the spark plug hole thanks to a drunken buddy of mine... Any ideas on how i could get this out the easy way without screwing my engine all up??
Old May 18, 2017 | 12:16 AM
Sam I Am's Avatar
Sam I Am
Get your buddy drunker this time, then he should be able to fix it.
Old May 18, 2017 | 09:17 AM
projectSHO89's Avatar
projectSHO89
The easy way is now long gone.
If you cannot extract the stripped tap, remove the head and take it to a machine shop or replace the head.
Send the bill to the drunken buddy (or find a new friend).
Old May 18, 2017 | 09:40 AM
Super DutyDave
Ahahah thanks for the advice yall, my brother is coming down this weekend hes a mechanic So hopefully he will know what to do... Maybe we could use some long visegrips so i can pull up as im turning.. He has the 5.4 triton engine too supposedly this is a common problem on theese blocks.. Theres only 4 threads holding a sparkplug with 10 threads in place... So thats why they rattle loose after getting rusted.
My brother fixed his and his neighbors using speaker wire lmao thats why i figured it would be hard to screw it up but i guess i spoke too soon..
Old May 18, 2017 | 09:45 AM
redford's Avatar
redford
FTE Leadership Emeritus
He is a "mechanic" that repairs blown spark plugs on Triton engines with speaker wire?
Old May 18, 2017 | 09:53 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
I think I saw MacGyvr do that once. I did see him weld up a broken connecting rod with a battery, battery cables and a steel rod. After that, the speaker wire thing should be easy.
Old May 18, 2017 | 10:20 AM
Chuck's First Ford's Avatar
Chuck's First Ford
I have seen a cracked exhaust pipe welded with a car battery.. battery cables and a metal clothes hanger...
not a connecting rod... pressed iron does not weld good.
Old May 18, 2017 | 10:25 AM
projectSHO89
Theres only 4 threads holding a sparkplug with 10 threads in place...So thats why they rattle loose after getting rusted.
Actually, that's NOT why they blow out. Even heads with full threads spit out plugs.
If you get it out, skip the Helicoil junk and go straight to with a CalVan (Snap On) or a Timesert. More than half of my Timesert rental inquiries come from guys with blown helicoils.
Also, re-torque ALL spark plugs DRY to 28 lb-ft. That will keep them from blowing out in the future.
Good luck!
Old May 18, 2017 | 10:30 AM
NewEnglandHerdsman
Not having seen your exhaust pipe installation, I can't say for sure. But the typical connecting rod is exposed to a bit more stress than an exhaust pipe, lol.
Old May 18, 2017 | 12:32 PM
Diamnd1's Avatar
Diamnd1
Afterwards it won the truck pull championship!
Old May 18, 2017 | 08:45 PM
R&T Babich's Avatar
R&T Babich
... Theres only 4 threads holding a sparkplug with 10 threads in place... So thats why they rattle loose after getting rusted. ....
The plugs rarely rust.
You'll have misfires to deal with before they rust when water gets down in there.
How many miles were those plugs in there?
The plugs will loosen because of the difference in expansion from heat for steel versus aluminum.
They can blowout even in the 8 thread heads.
I change plugs/boots/springs at 50k, use nickel antiseize, torque to 25 ft/lbs and check torque one more time at 10k.
Haven't had any more problems since I blew a factory installed plug at 108k.
Used a TimeSert kit to fix mine, they have a special oversize insert to repair Helicoil blowouts.
Old May 18, 2017 | 09:17 PM
dkf's Avatar
dkf
The Helicoil will blow, the junk kit from Autozone or Advanced will blow. Fix it with a Timesert (properly) and it will not blow out again. Sounds like with a stuck tap and all the screwing around you'll probably need an oversized Timesert to clean all the damage up.
Old May 19, 2017 | 02:58 PM
Optimistic Paranoid's Avatar
Optimistic Paranoid
Brownells (the gunsmith supply house) has always sold broken tap extractors, but only in the small sizes a gunsmith would need. (This is how I happen to know that such things exist)
A little research on the web shows that Snap On sells Broken Tap extractors.
Also the industrial supply house, MSC shows they have them in a range from #4 up to 1 inch.
https://www.mscdirect.com/browse/tn/...navid=12106011
Hope this helps. Good Luck!
hans2112
Aug 5, 2012 08:16 AM
johnburgelin
Jun 29, 2010 06:57 AM
kojak57
Jun 6, 2009 10:37 AM
FBOMBS
1997 - 2003 F150
19
Sep 20, 2006 08:37 AM
dassmoof
1978 - 1996 Big Bronco
Feb 16, 2003 09:54 PM
