squeeking in drivers side wheel
Old Apr 23, 2009 | 10:09 PM
61 uni's Avatar
61 uni
My drivers side front wheel has a squeeking noise wheen going around a sharp left turn and sometimes while braking. I thought the clips that hold the rotors were rubbing the rotor, but my new rotors still look good. Any ideas?
Old Apr 23, 2009 | 11:30 PM
tojoski's Avatar
tojoski
Mine has a squeak on the drivers side also. I couldn't find it when I had the suspension apart putting in the leveling kit.
Subscribing to see what ideas everyone comes up with..
Is it a continuous squeeeeek.. or more like squeak-squeak-squeak ?
Old Apr 24, 2009 | 12:51 AM
87 F-150 I6's Avatar
87 F-150 I6
Kinda sound like the hub assembly, mine when out and sounded just like that.
Links to help
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Old Apr 24, 2009 | 07:20 AM
61 uni's Avatar
61 uni
Links to help
It's 2 wheel drive.
Old Apr 24, 2009 | 08:44 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Could it be a bearing?
Old Apr 24, 2009 | 08:54 AM
61 uni's Avatar
61 uni
We repacked the bearing while we had the rotors off. They felt fine.
Old Apr 24, 2009 | 10:19 AM
87 F-150 I6
Originally Posted by 61 uni
It's 2 wheel drive.
Right, but it shows you how to get i there and re grease the bearings.
Old Apr 24, 2009 | 10:20 AM
87 F-150 I6
o, then it could be the breaks.
Old Apr 24, 2009 | 04:53 PM
61 uni's Avatar
61 uni
ok, i'm not going to rule out wheel bearings and i'm not 100% shure it is the front. It is definatly the drivers side. Is there anyway to check the wheel bearings without taking all of that apart again?
Old Apr 25, 2009 | 11:18 AM
61 uni's Avatar
61 uni
Anyone? I need to take it on a trip tomorrow.
Old Apr 25, 2009 | 03:57 PM
87 F-150 I6
You can jack that side off of the ground and see how much play you have as you rotate the wheel up and down / left and right. There should be very little to no play as you try to rotate up and down and little on the left and right. I did this when I had my passenger side go out and found out I had excess play up and down. Also when you have it off the ground, spin that wheel and listen and feel if it grinds. To check the breaks you will need to take that tire off, but that's pretty easy.
samohtman
1997 - 2003 F150
Nov 8, 2009 09:17 AM
jefxxo
2004 - 2008 F150
May 12, 2009 09:58 PM
jdecker88
Feb 9, 2009 09:03 AM
Benny2002
15
Feb 6, 2008 10:46 AM
technoman26
May 3, 2006 06:10 AM
