The fuel in the bottle is what was drained from WIF plug.
Yeah those filters look normal to me, there's no way to tell they've had 2-stroke-oil run through them...and as far as the tequila bottle goes....I'm relieved to find out thats fuel in there...
Great idea, then put the 30 oz into 25 gal of diesel fuel?
Well, I have a bigger tank, usually fuel 30-32 gallons on each fill. But, with 25 gallons, it should be fine.
I make up a few bottles at a time, then grab and fill. (I have a tool box to store them in. You don't want to keep this in the cab, Diesel Kleen bottles have a tendency to leak.) Some folks use plastic soda bottles.
Thanks for sharing.
I think I will use the same ratio you are using, it has been proven to work. I do run Diesel Kleen now so I will try some 2-stroke mix. I am getting ready to do a few hr trip, this will be good test.
