1316 trouble code
Old Mar 19, 2009 | 08:50 PM
hndamxmn's Avatar
hndamxmn
1316 trouble code
I posted a thread a whili back after reading another post about " truck shakes between 40-50 mph" my truck had the same thing going on. I followed the steps on how to check the continuity on the injector harnesses and all were good.
Chris then suggested taking my edge evolution programmer off and running it stock.
I did that and the check engine light went off and I didnt feel the "shake" between 4-50 anymore.
The more I drove it I noticed a slight shake but at a different mph range and the check engine light went back on and up pops the 1316 code again.
I programmed my truck back to race mode (stock mode sucks) and the code was off for 3 days and back on permanently.
Any advice what to do next?
oo' f350SD 4x4 w/ edge evolution programmer
Old Mar 19, 2009 | 08:55 PM
Pocket's Avatar
Pocket
Get a hold of a diagnostic tool that can pull codes out of the IDM. P1316 means that there are codes stored inside the IDM, and your Evo and other handheld code scanners cannot pull IDM codes.
Old Mar 19, 2009 | 09:07 PM
MADVAN's Avatar
MADVAN
X2
You have to do a CC or buzz test.
The test will pull out the IDM codes.
Bill
Old Mar 20, 2009 | 03:54 PM
hndamxmn's Avatar
hndamxmn
alright I'll try that and let you know what the codes were. Thanks
Old Mar 23, 2009 | 11:39 AM
hndamxmn's Avatar
hndamxmn
went to a shop today and had a guy run the test and he got an idm code of 1263 and said it had something to do with the #3 injector. What is the process or the next step. He also said right when he started my truck that it had a miss just by hearing it. The #3 injector and pass. side harness were replaced prior to this problem but have having codes since.
Old Mar 23, 2009 | 11:53 AM
tdpower's Avatar
tdpower
If they only did a buzz test it might be an injector solenoid. Try omhing out the I to C measuresments and compare the various injectors. Test this at the 9 pin of the valve cover (male side). You can also get a pigtail for testing that makes it easier to test.
G - G - I - I - C - I - I - G - G
Old Mar 23, 2009 | 12:00 PM
hndamxmn's Avatar
hndamxmn
I had already done this check prior to this and all had checked out. Then I was advised to have the idm codes checked and thats where I'm at now
Old Mar 23, 2009 | 12:12 PM
tdpower's Avatar
tdpower
I would say you either have a wiring issue between the idm and injectors or a bad IDM. Maybe you know someone you could swap out an IDM with.
Old Mar 23, 2009 | 12:29 PM
hndamxmn's Avatar
hndamxmn
is there a way to check the wiring on the idm or any way to check and start this process to figuring it out?
Old Mar 23, 2009 | 09:29 PM
MiamiPSD's Avatar
MiamiPSD
What is the scanner to have in our tool box to pull codes and diag our trucks? I have a 03-7.3L.
mylakers
41
Nov 11, 2016 05:13 PM
marc13
29
May 17, 2012 01:19 PM
monsterballz
Mar 17, 2011 12:28 PM
hndamxmn
Apr 28, 2009 06:15 PM
hndamxmn
Jan 9, 2009 06:20 AM
