powerstroke p1316
Old Mar 16, 2011 | 01:17 PM
monsterballz's Avatar
monsterballz
powerstroke p1316
i have 2000 f350 7.3 4x4 drw .ok heres the problem everytime i put the truck in gear the service engine soon light comes on and the truck runs rough if i put it back in park or neutral and wait about a minute the light turns off and the truck runs great .i checked and erased the code every time it happens and the only code there is P1316 and from what i can find on the internet that is a idm code .thanks for all the help in advance.
Old Mar 16, 2011 | 04:53 PM
BigAlsPSD's Avatar
BigAlsPSD
It is an IDM code, before clearing the code, perform a KOEO self test or buzz test which will ping the IDM for the codes that it has stored, 1316 is just the PCM code saying the IDM has stored codes which need read. Your issue sounds like possibly a loose UVCH or an injector that is not firing cold. Look at the 7.3 forum for some great info... 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Mar 16, 2011 | 07:21 PM
F350-6's Avatar
F350-6
Welcome to FTE. I'm with Alan on this. Loose UVCH.
Read this thread https://www.ford-trucks.com/forums/8...ck-shakes.html it's got pictures and even a video toward the end showing how to fix this.
Old Mar 16, 2011 | 08:36 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old Mar 16, 2011 | 09:07 PM
clintbonnie's Avatar
clintbonnie
Yep.. a loose piece of junk 9 pin plastic connector/s under your valve cover/s has come loose.. somewhat easy fix... you can reuse the valve cover gaskets.. and 2 quarters, slightly modified and you are back running good again.. Just follow link Chris has in post #3.
Old Mar 17, 2011 | 11:36 AM
monsterballz
ok i ohmed the connectors and heres what i got driver side injectors 5.5, 3.1, 3.0, 3.0, driver side glowplugs 0.8, infinity, 0.8, 0.8 .passenger side injectors 3.5, 3.3, 3.2, 3.4 passenger side glowplugs 1.2, 1.4, 1.3, 1.3 .how can i tell which side is bad or do i change both.
Old Mar 17, 2011 | 12:17 PM
Brother Les's Avatar
Brother Les
You don't 'change' anything. Just make sure that they are plugged in really tight and then do the 50 cent mod to make sure that they do not back out again.
Welcome to FTE
Old Mar 17, 2011 | 12:28 PM
clintbonnie
Keep in mind when checking ohms on your harness, it is sometimes hard to catch the loose connector exactly when it is loose.. You should just remove the covers and fix it like brother les says.... (better now than when you are on vacation in ten buck two)
choskins
May 16, 2016 08:20 PM
71offshore
Sep 1, 2015 07:37 PM
hiattk
Apr 26, 2013 11:40 AM
superchief
Feb 5, 2012 10:10 PM
asp84
Dec 11, 2008 02:00 PM
