Part VI
Old Sep 29, 2009 | 09:08 AM
  #19411
AzBlueWolf's Avatar
AzBlueWolf
morning all!
Turbocharger
The 6.7L uses a Garrett single sequential turbo (SST) with variable geometry, a dual-scroll exhaust housing, and an externally actuated wastegate. This turbo has a pair of compressor wheels that are coupled together on a single shaft driven by the turbine wheel. The design is said to dramatically increase the compressor map's range and functions like a sequential twin-turbo system. The boost pressure will be around 30 psi, the turbine shaft speed will see up to 130,000 rpm, and the whole system was designed to function as an exhaust brake. The compressed air will be cooled by an air-to-water intercooler-another first in this segment.
The turbo is bolted to the top of the engine with a pedestal mount attached to the bearing housing (not the exhaust housing, as is commonly done) for less noise and longer turbo life. The twin compressor wheels are mounted back-to-back on a massive turbine shaft that's driven by a single turbine wheel. The variable geometry turbine uses a relatively small housing that also features an external wastegate actuator to divert exhaust drive pressure around the turbo.(Thanx Dieselpower)
Old Sep 29, 2009 | 09:32 AM
  #19412
DieselCamper01's Avatar
DieselCamper01
How the he!! did you do that Mark?
Old Sep 29, 2009 | 09:34 AM
  #19413
Sparky83's Avatar
Sparky83
Originally Posted by DieselCamper01
Trying to post a picture of the new turbo without any luck. Geez I suck at computer crap. Something so simple I cannot even do
you aint the only one to suck with computers...
Old Sep 29, 2009 | 10:03 AM
  #19414
DieselCamper01
People post pictures and links all day long and I struggle every time
Old Sep 29, 2009 | 10:08 AM
  #19415
tjc transport's Avatar
tjc transport
i ain't rite
Originally Posted by sddesigns
Good Morning All....
Hey Alicia how's it going?
Good Luck Lisa, when in doubt, "C" out......
Tom, you coming up to Jim's Injector Fest?
when is it??
Old Sep 29, 2009 | 10:12 AM
  #19416
Sparky83's Avatar
Sparky83
its something ya gotta learn.... i grew up learning how...
  #19417
AzBlueWolf's Avatar
AzBlueWolf
to post an image from the net:
right click on the image and click on properties
copy the url address
close the window
in the FTE message box type [img] paste the url address here [/img then put the other ] after the g
Old Sep 29, 2009 | 10:28 AM
  #19418
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by tjc transport
when is it??
https://www.ford-trucks.com/forums/8...-been-set.html
October 17 -18, Matt (mxracer3276) and Jim (rat49f6) are leaving sometime Friday afternoon, and I'm going up for the day on Saturday the 17th.
Old Sep 29, 2009 | 10:32 AM
  #19419
Sparky83's Avatar
Sparky83
close the window
actually depending on your computer setup ya might not want to close the window before pasting.. one of my computers here loses the "copy" if ya close em before ya paste the links... even run into that with other computers as well... windows doesnt normally do it but have had it happen on occasion... just the way people set them up..
Old Sep 29, 2009 | 10:35 AM
  #19420
AzBlueWolf's Avatar
AzBlueWolf
mine wont let me do anything until I close the window
Old Sep 29, 2009 | 10:41 AM
  #19421
AzBlueWolf's Avatar
AzBlueWolf
I have a program called 101 clips...allows me multiple clipboards and even keeps them when I reboot
Old Sep 29, 2009 | 10:44 AM
  #19422
DieselCamper01
I am stupid. No getting around it. lol
Old Sep 29, 2009 | 11:01 AM
  #19423
AzBlueWolf's Avatar
AzBlueWolf
nah...sometimes you learn easier if someone walks you thru the steps 30 or 100 times first~
Old Sep 29, 2009 | 12:17 PM
  #19424
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
save copy, upload to photo bucket then copy link and paste.
duh!
lol
burn
hea Jay how ya doing! slow ?
hahahhahahahaha
Old Sep 29, 2009 | 01:08 PM
  #19425
DieselCamper01
Yeah, but I don't believe I should have to load everything to Photobucket first. There HAS to be an easier way? Yes, Yes I am slow. Cannot teach an old dog multistep new tricks
