Sponsored by: Real Truck
trans temp problem
Old Feb 21, 2009 | 08:09 AM
1975StroppeBaja's Avatar
1975StroppeBaja
Sounds to me like your gauge is working fine. Last night I drove home (about an hour drive, across one mountain) and my gauge was basically dead on 120 deg. It was about 15 deg outside.
Old Feb 21, 2009 | 07:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by JockD
Mark, Is there a way to modify the stock gauge system to make the temperature gauge jump up to "hot" at say, 200 degrees? Adding a resistor or something? That would give a savvy owner better warning of pending overheat.
The PCm sends trans temp data to the instrument panel. The instrument panel has a microprocessor that decides what to do with that info. You need to reprogram the instrument panel micro to change how the gauge operates. A resistor isn't going to do it.
Old Feb 21, 2009 | 08:27 PM
tex25025's Avatar
tex25025
Could you do that thru PTDIAG?
Old Feb 22, 2009 | 01:55 AM
soutthpaw's Avatar
soutthpaw
My OTC Genisys scan tool actually gives me 2 readings for trans temp the before and after trans cooler temps... I was running it on the truck today and the before cooler temp was around 150 and the after cooler temp was around 115 120 seems the stock cooler does about 30F reduction in temp. ambient temps were in the 50's today... Really making me consider an external trans cooler... as the stock cooler in the radiator is only at the temp of the coolant that has just flowed thru the radiator...
Old Feb 22, 2009 | 08:11 AM
Mark Kovalsky
I don't know what PTDIAG is, so I can't answer this. It would need to let you access the micro in the instrument cluster, download the software from it, modify the code, and reload the modified code back into the micro.
How does it do that? Did you add another sensor? The stock trans only has one sensor.
...which is quite a bit cooler than the temperature when it entered the radiator, or the radiator isn't working.
Old Feb 22, 2009 | 01:04 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
My 4R100 sits at around 150F on the hottest day of the summer, unless I am really REALLY working it.
During the winter, the gauge never moves.
Aftermarket Autotemp gauge.
FORDF250HDXLT
Oct 22, 2012 04:38 PM
dave23
Nov 19, 2010 09:05 PM
RussB
Jun 6, 2008 11:53 PM
chritter
May 8, 2008 12:03 PM
YellerMax
Dec 7, 2006 12:12 PM
