Trans temp gauge??
Old Nov 19, 2010 | 08:06 PM
dave23's Avatar
dave23
Trans temp gauge??
i just recieved my Auto meter gauge kit for my 2000 ford excursion with a 7.3 and i am wondering if the trans may have a fitting that i can pull out to install the probe....or do i have to remove the trans pan and drill a whole and weld a bung on it?? thank you!!!
Old Nov 19, 2010 | 08:44 PM
mueckster's Avatar
mueckster
The sender goes in the test port on the left side of the trans just above the pan in front of the shifter linkage. I have Autometer gauges too and ran the wire from the sender up the cable and into the cab past the boot on the floor.
Shake-N-Bake's Avatar
Shake-N-Bake
There should be a 1/4" NPT plug in a test port on the driver's side just behind the gear selector assembly. You can put your sensor in that port if the threads are the same.
Edit: mueckster is correct. It's forward of the gear selector. (my bad)
Old Nov 19, 2010 | 08:50 PM
tdpower's Avatar
tdpower
This should help: 3-Gauge Install Pictures
Also their instructions on gauge install: Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old Nov 19, 2010 | 08:56 PM
dave23's Avatar
dave23
you guys are the best! i am new to the diesel world and loving it!!
Old Nov 19, 2010 | 09:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's a 1/8" NPT thread, not 1/4". Most gauge senders are also 1/8" NPT.
Old Nov 19, 2010 | 09:05 PM
Shake-N-Bake
Oops! Absolutely correct. Major typo. Thanks for catching that Mark.
garsm
Oct 7, 2016 09:03 AM
tgosser
Jul 17, 2016 06:40 PM
Spades
Jul 11, 2016 11:48 AM
AKHunter93
17
Jun 4, 2015 10:18 AM
AC-MAN
Jul 18, 2011 11:29 AM
