Sounds to me like your gauge is working fine. Last night I drove home (about an hour drive, across one mountain) and my gauge was basically dead on 120 deg. It was about 15 deg outside.
Mark, Is there a way to modify the stock gauge system to make the temperature gauge jump up to "hot" at say, 200 degrees? Adding a resistor or something? That would give a savvy owner better warning of pending overheat.
The PCm sends trans temp data to the instrument panel. The instrument panel has a microprocessor that decides what to do with that info. You need to reprogram the instrument panel micro to change how the gauge operates. A resistor isn't going to do it.
My OTC Genisys scan tool actually gives me 2 readings for trans temp the before and after trans cooler temps... I was running it on the truck today and the before cooler temp was around 150 and the after cooler temp was around 115 120 seems the stock cooler does about 30F reduction in temp. ambient temps were in the 50's today... Really making me consider an external trans cooler... as the stock cooler in the radiator is only at the temp of the coolant that has just flowed thru the radiator...
I don't know what PTDIAG is, so I can't answer this. It would need to let you access the micro in the instrument cluster, download the software from it, modify the code, and reload the modified code back into the micro.
How does it do that? Did you add another sensor? The stock trans only has one sensor.
...which is quite a bit cooler than the temperature when it entered the radiator, or the radiator isn't working.
