Rear Differential temp gauge
Old May 7, 2008 | 09:09 PM
chritter's Avatar
chritter
I just installed an auto meter rear diff temp gauge. the sender is in the top of the mag-hytech cover, but I'm getting vey inconsistant readings. I only get a reading over 100 deg when I take off from a stop or get in the pettal going down the road. Oil level is right where it should be. Any thoughts on the sender being bad or the gauge?
Old May 7, 2008 | 09:26 PM
bigsteve1969's Avatar
bigsteve1969
does the oil go all the way to top in rear diff? i thought you were supposed to leave a little room for it to slosh around? maybe cause for your inconsistant reading i know my level is not full to top so it could just be the way the international place done it on the last owner
Old May 7, 2008 | 09:34 PM
chritter's Avatar
chritter
No I believe they are only supposed to be filled to the bottom of the axel , and the mag covers have a dip stick that showes a full level of about half way up the diff cover.
Old May 7, 2008 | 09:36 PM
bigsteve1969
so where is your sensor in the top or where it will always come in contact with fluid
Old May 7, 2008 | 10:01 PM
chritter's Avatar
chritter
It's in the top, which seemed to me not the best place for it but it's the only place on the cover that a sender will thread into. I thought it should be in contact with the fluid also.
Old May 7, 2008 | 10:07 PM
bigsteve1969
i would call and ask mag-hytech and see what they say but i mean if it doesn't come in contact with the actual fluid its not gonna get true reading (we both agree) i dunno much on those covers but they may have one that has a bottom side port also and you may could just drill and tap your own
Old May 8, 2008 | 12:40 AM
SpringerPop's Avatar
SpringerPop
Does this sensor have one wire or two attached to it.
If it has only one, you need to run a very flexible ground wire from your differential housing to a good clean frame ground.
Pop
Old May 8, 2008 | 12:03 PM
CSIPSD's Avatar
CSIPSD
Your sender needs to be on the bottom of the diff cover in order to read the temp of the oil... Like this...
Crewcabber
Sep 8, 2015 07:11 PM
oft
Oct 20, 2014 05:30 PM
kabcpapc
1997 - 2003 F150
Sep 6, 2014 03:53 PM
snowdog79
Jan 23, 2014 10:28 PM
Sooper Camper
Nov 30, 2013 09:24 PM
