I have been following this thread for awhile now and I guess I am still confused. I have a Zune that I currently have to use the FM modulator to get it to work in my truck because I don't have an audio input on my stock radio. It is the 6 disc changer model. It has the aux function button so, does that mean it has the input in the back that I could wire up something like you guys are talking about?
there are two possible ways to hard wire an aux input to ur truck i have been lookin at them to find out which one is better but the two options are the hardwired fm modulator like mentioned and if you have the sirius satellite radio option in your truck you can buy the connector the bypasses that connection on your stereo. that is of course if you dont use the sirius option, which i dont wanna pay for the service so i may take that route.
the whole point of the FM modulator is that you don't have to wire anything in...just select the broadcast station the modulator is sending on and listen to your tunes
Kind of what I was thinking. Unless you get less static?
Well here are the pics of how I did it. You really cant tell that chip is there when you look at it unless you really look at it. Once the cable is plugged in you cant even see it at all. If I had a newer drill bit Im sure it wouldnt have done it. Works good and its pretty sturdy just sitting in there. Never had it fall in the back.
What's that button to the right of the 3.5 jack? It has a "P" and says off...
The wireless modulators aren't very good....i bought two different ones for her before i gave up due to static and interference.....her car has no input that i could wire in directly, so the fm modulator that wires in is MUCH more powerful and is crystal clear...
that would chip the plastic much more than a regular HSS bit as soon as the tines hit it.
The tines score the outside of the hole before any material is removed. I know in any material I've used them on they always make a cleaner hole than a regular bit.
As I stated above I would get a piece of similar plastic and test every type of bit available before I drilled the hole in the dash.
But hey opinions are like *********s, everybody's got one
Easy killer....Yes, the timns are on the outside, so when they contact plastic, with their sharpness, they are going to hit it with a sharp edge, doing XXX RPS. with a beveled drill bit, aka HSS (which will work on plastic) it MIGHT chip the center, but then evenly hollow out the 3.5mm needed for the jack to fit.
Like you said, opinions are like *******s, everyone has one, but most smell like ****.
ChargersFanInCO-Sorry man, I'm feelin a little stressed the past while and I'm not my usual happy go lucky self!! If you've tried the bit I'm talkin about then fair enough
Hey everyone. I dont know about the newer models. But for my 2001 there is a port on the back of the stereo for a CD Changer imput. There is an Aux module that hooks into that then you can get a Ipod cable that hooks into that module. Then you can fish the Ipod cable anywhere you want so its out of the sight of the bad guys. To access your Ipod you just push your CD button 2 times. That way your not drilling holes and jimmy rigging your nice truck. Also the sound is about 1000 times clearer with the set up than the headphone hookup. And without 5ft of cable hanging around. Hope it helps
