MP3 jack
Old Feb 19, 2009 | 04:49 PM
Still Smoking's Avatar
Still Smoking
I know exactly what you are talking about. I got a fx4 with the center shifter and it didnt have the mp3 jack. So I had to buy a pie adapter. Then I had to get a 3.5 mm male and female cord. I took some measurments between the reverse sensor and cig lighter. I got a drill bit that was just a hair smaller than the female plug. Not real small but for a snug fit. From there I drilled in the center of the panel. I then pushed the plug in from the back. It works great never poped out or anything. It has a clean look cause the plug sits flush with the face of the panel. The only thing I didnt like when I was drilling through the plastic is that it chipped a real small piece. You cant notice it unless you really look at it. Other than that it looks good. I will try to get some pics up for you. It might not be till later though.
Old Feb 19, 2009 | 04:51 PM
Ryan50hrl's Avatar
Ryan50hrl
I really can't believe there isn't a good jack made thats designed to push into a hole of a certain size.....I thought about using that idea of just pushing the cord female end in tight....but wanted something more secure...
Old Feb 19, 2009 | 05:31 PM
WhëëlMå1's Avatar
WhëëlMå1
The only thing that is going to work for you Ryan is a panel mount, similar to what I linked to. I have never come upon a flush mount panel fixture. I will see if I can take a photo of a similar product, that I have at work (installed into some sheet metal).
Old Feb 19, 2009 | 05:46 PM
WhëëlMå1's Avatar
WhëëlMå1
Ok, I found a couple of poor photos here on my laptop. The exposed section of that style mount is probably around a half inch or so.
Here is a shot of the side profile (these are S video and RCA... but they should be the same in essence)
Here is a front-on shot:
Old Feb 19, 2009 | 05:50 PM
WhëëlMå1's Avatar
WhëëlMå1
Its the wrong male termination, but we are getting closer to what I think you might want
Panel-Mount 3.5mm (F) to RCAx2 -- DataPro
Old Feb 19, 2009 | 05:52 PM
WhëëlMå1's Avatar
WhëëlMå1
Reading back, you say you want to keep the stock jack.... do you know how it is terminated behind the dash? How about the interface at the deck? I'd like to help you find a work around here, but I worry there might be signal loss if we simply use a jumper system.
Old Feb 19, 2009 | 07:55 PM
Ryan50hrl's Avatar
Ryan50hrl
My plan is to get another stock jack and solder the wires of a male end onto it...use that one in the upper location, get a y-adapter, plug it into the original in the dash and then use the y to go to both locations...
Old Feb 19, 2009 | 08:07 PM
WhëëlMå1's Avatar
WhëëlMå1
Won't that Y defeat the purpose of a stealth?
Old Feb 19, 2009 | 08:13 PM
Ryan50hrl's Avatar
Ryan50hrl
the y will be inside the dash.....allowing both jacks to work....
Old Feb 19, 2009 | 08:15 PM
WhëëlMå1's Avatar
WhëëlMå1
Ahh gotcha.
Old Feb 19, 2009 | 08:18 PM
Ryan50hrl's Avatar
Ryan50hrl
I guess i don't know why its so important for me to have both work.....other than i don't want a hole in the top.....and i'm kinda picky like that.....Plus i don't want anyone to plug something into it and it not work......lol...i guess it would be slightly easier to just not worry about the y....but thats the easy part...finding a suitable jack to mount in the dash is becoming the hard one
Old Feb 19, 2009 | 08:45 PM
coronacraft's Avatar
coronacraft
i found this jack on the net it may be better but i dont know how legit the dealer is, i have been trying to figure out the best way to add a mp3 jack to my truck and i have seen all the options i just dont know which one is the best way. i have the audiophile in dash 6 CD changer with sirius but i hate radio regardless id rather run my mp3 player or laptop to have my itunes library in my truck anybody got ideas?
audio jack website:PDM35 - Peripheral PDM35 3.5mm Dash Mount Audio input - .Browse By Vehicle - Car Video - CD Changers - iPod? Adapters - Accessories - Discount Car Stereo.com - Detail
Old Feb 19, 2009 | 09:04 PM
  #28
67tony's Avatar
67tony
Sorry if this is a naive question...but are we saying that the back of the factory head unit will accept these (red & white) rca inputs?
Old Feb 19, 2009 | 09:11 PM
  #29
WhëëlMå1's Avatar
WhëëlMå1
I only posted a similar cable, to show Ryan the front termination (female portion). I honestly dont know what inputs the stock deck has.
Old Feb 19, 2009 | 09:24 PM
  #30
Ryan50hrl's Avatar
Ryan50hrl
No...the deck i don't believe has any jacks other than the pin ones....
Thats close...although i'd prefer it didn't have writing on it.....
