DP Tuner Not Working
Old Jan 10, 2009 | 02:10 PM
Bigcat350's Avatar
Bigcat350
I need some help here. I just installed my new DP Tuner with no problem and then started the truck it started fine but my F5 switch did not light up and I cant get it to come on. IT dont show any thing and theres no CEL on in the truck.Any ideas.
Old Jan 10, 2009 | 02:12 PM
aklim's Avatar
aklim
One. Are you SURE that the connection between the chip and the module is tight? MAKE DAMN SURE THAT YOUR KEYS ARE FAR AWAY when you do this.
Old Jan 10, 2009 | 02:24 PM
Bigcat350's Avatar
Bigcat350
It looked good to me. I did rub the silicon off good I thought. Will the truck even start it its not getting a good connection?
Old Jan 10, 2009 | 02:27 PM
aklim's Avatar
aklim
Truck could still start. It just might not get input from the F5. What I was wondering is if the wire between the F5 and the chip itself is good.
Old Jan 10, 2009 | 02:28 PM
hucka1a's Avatar
hucka1a
This is straright from DP's website. Q:I just installed my chip and the F5 switcher does not illuminate. What is going on?
A:Unplug the switcher.Turn it around and look at the line up of the cable notches. Verify that the cable is lined up correctly. The notch will be be down on the switch and up on the cable.
If that doesn't fix it. Post on DP's forum, they'll get in touch with you.
Good Luck
Old Jan 10, 2009 | 03:10 PM
Bigcat350's Avatar
Bigcat350
Got it going.Its warming up now. Gotta go see what it will do.
Thanks all.
Old Jan 10, 2009 | 03:12 PM
Izzy351's Avatar
Izzy351
Fill your tank -- it will empty quickly now.....
Old Jan 10, 2009 | 03:36 PM
jeff7825's Avatar
jeff7825
Good Luck
This is what I did with mine when I put it in, but my truck wouldn't start. Anyhow, glad you got it working.
Old Jan 10, 2009 | 05:02 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Thanks all.
Hope it's running well for you Eddie.
Edit:, never mind, saw the other post.
rich gill
Aug 10, 2009 04:23 PM
Blacked-Out
May 6, 2009 06:52 AM
fisherman2626
Apr 7, 2009 07:48 AM
MAKO314
19
Jan 9, 2008 08:38 AM
MAKO314
Jul 28, 2007 03:36 AM
