I just reinstalled my DP tuner after a no start issue, that I got fixed. now with the dp installed ,no start- w/o dp runs fine. do any of you know what I've done? have I burned up the chip?
I had the same problem and it ended up that my circuit board needed to be cleaned some more. Maybe try a quick wipe with some finger nail polish remover.
Yep, as 62trvler suggested, make sure the contacts on the PCM are cleaned off of all the silicone goop. Needs to be a nice, clean, firm contact... tape the chip in place with duct tape, as well.
If after assuring a clean connection, you still start up fine w/out the chip, but no start with the chip, then I'd say there's an issue with the chip.
