Pull intake again? wtf!
Old Jan 6, 2009 | 07:45 AM
  #31
Redmanbob's Avatar
Redmanbob
Originally Posted by 78ford351m
I am almost certain this is why. I tore it a part last night, cleaned it, used the "right stuff" can recommended by the engine shop. Then I torqued to spec. After that I added more on the outside. No way it will leak now. I will be so pissed if it does.
It's an FE I'd be pissed if it didn't leak(eventually)
Old Jan 6, 2009 | 08:25 AM
  #32
78ford351m's Avatar
78ford351m
This is the reason I bought the good stuff. We'll see how long it lasts.
Old Jan 6, 2009 | 08:30 AM
  #33
krewat's Avatar
krewat
FTE Leadership Emeritus
A few comments:
1) It seems that aftermarket intakes like the Edelbrock, or when the heads have been milled, means you can't use the cork gaskets, they are too thick.
2) If you do use the cork (and maybe even rubber) gaskets, do NOT RTV both sides of it. Use Permatex Hi-Tack or something similar (rubber glue, basically) and tack one side of the cork to the block. This keeps the cork from slipping out (works great on oil pans and valve covers too). Put a coating of Hi-Tack on the cork and on the block and allow it to become tacky then put in place.
3) I've used RTV on FE's and never had a problem. Of course, if I was in a hurry, a little oil/grease on the surface will ALWAYS cause a leak.
Good luck
FE's are like English sports cars. You know you're low on oil when there's no spots in the driveway
Old Jan 6, 2009 | 08:56 AM
  #34
78ford351m's Avatar
78ford351m
Originally Posted by krewat
A few comments:
Good luck
Well I didn't have oil leaks, just coolant getting into the motor in the wrong spots. I had no leaks what so ever until now. These are great motors.
Old Jan 6, 2009 | 10:08 AM
  #35
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Hi-tack is great for placing the intake gaskets onto the cylinder head too.
My dad got me hooked on "Indian Head" gasket shellack for tacking cork gaskets down. Also good for sealing threads too.
Just wait until the rear main starts leaking.
Josh
Old Jan 6, 2009 | 10:54 AM
  #36
78ford351m's Avatar
78ford351m
Josh
According to the engine shop here, "right stuff" is the best you can get. It seals when no other can, tough, and last forever. We'll see.
Old Jan 6, 2009 | 05:32 PM
  #37
OrangeJuice's Avatar
OrangeJuice
78Ford351M, let us know how it worked.
Old Jan 6, 2009 | 07:23 PM
  #38
78ford351m's Avatar
78ford351m
I promise if it works, I'll stick with this. I picked up a water pump today and I'll be sealing it with the same stuff. Might as well change that out while I'm half way there anyway. Heck, I should have just pulled the damn heads and did those too, but I'm not that rich...
michbol
Nov 14, 2011 01:25 PM
sdg0080
Mar 30, 2010 01:34 AM
MinnesotaJeff
Mar 6, 2005 10:36 AM
niteowl
19
Dec 1, 2003 09:20 PM
Ratsmoker
Feb 3, 2002 08:22 PM
