$3600 For Shortblock ?
Old Jan 6, 2009 | 01:31 PM
393STROKER's Avatar
393STROKER
Thumbs up $3600 For Shortblock ?
I got my 390/436 block back today and the total came out to $3600 and change.That was for the machine work,stroker cast crank,H-beams and SRP pistons,and labor,without a cam.It`s a good build but seems a little on the high side.Does that seem about right ?
Old Jan 6, 2009 | 03:08 PM
maxtor's Avatar
maxtor
It looks pretty close. Figure $1,000 for machine work, $2,000 for stroker kit, and $600 for putting the short block together and you are right there. A cam is in the block now right?
Old Jan 6, 2009 | 04:11 PM
393STROKER's Avatar
393STROKER
Thumbs up
No,I wanted to get a roller but didn`t want to spend any more money right now.Plus I dont know how big of a cam I want to put in it.I know that a regular would work OK, but since I put a roller cam in the small block I`m hooked on the rollers.USA Racing in Houston did the work,they`re one of /if not the best shops around.I got the Cobra Jet heads I found off that old truck I got awhile back that I`m planning on using after I get them to look like yours.Anyway,thanks for the reply,I just wanted to know if I was in the ballpark on the cost.
Old Jan 6, 2009 | 04:57 PM
maxtor's Avatar
maxtor
If you have the extra money, you can replace the 2.09 intake valves with a set of 2.15 intake valves. I had to have a set of 2.19 cut down to 2.15 but you might find a set already at the 2.15 size if you are not in a hurry.
A good race valve job cuts the valves to 45 degrees, not the 30 degree stock cut. 45 degrees flow much better at the higher valve lifts.
Old Jan 6, 2009 | 10:28 PM
393STROKER's Avatar
393STROKER
What would be a good aluminum intake to put on it ? I have the CJ cast iron one now.And I`m going to put the bigger valves in like yours.I just bought a`88 F-350 4x4 w/brand new 460 that the guy didn`t finish putting back together for $1000.Just unloaded it,couldn`t pass it up.
Old Jan 6, 2009 | 11:07 PM
maxtor's Avatar
maxtor
Sounds like you got a great deal on your F350.
For the money it is hard to beat the Edelbrock rpm manifold. Your manifold is a good manifold, but it is nice to loose all that weight by installing a aluminum manifold. Ford made some very good aluminum manifolds , but it is nice to buy new, and not have to worry about buying a used manifold that might have some issues. Sometimes inexpensive used manifolds can end up costing you a bunch because of problems like previous milling, broken or cracked areas, damaged threads etc. Just depends on your budget.
Retiredfire
Jan 5, 2014 10:43 PM
Delta2142
6.4L Power Stroke Diesel
19
Jan 27, 2013 07:02 PM
zach2004
Aug 14, 2004 08:53 PM
mustange70
15
May 9, 2002 11:55 PM
xyfalcon500
Mar 2, 2002 10:23 PM
