Whats the code and how do these boots stack up to Bobs or Pure diesel powers? There really isn't much of a description there.
I apologies for the lack of description on our site, I am glad you asked though, there really is a lot more to these boots than meets the eye!
The BD boots are made from 4-Ply Nomex, heat temp fiber. They are Fluoro Silicon lined to repel residue build up and eliminate deterioration caused by the crank case recirculation discussed earlier in this thread. Some other areas that separates us from our competitors is that we use the same die as Ford to insure a OEM fit. The ribbed wire hose will fit right into the grooved pipe and increase holding strength while preventing ballooning, our clamps are rated for 400/lbs.
I just tried to look for boots,I got no idea how you would find anything on that web site
Are you referring to our BD Diesel site? If so I apologies if you are having troubles finding the boots, we do have a lot of products to navigate through. You can find them Under the Ford tab, then the intake category. I did post the link in my original post but will post it again. Click HERE
When you know the difference you will choose BD!
I don't imagine that y'all have these boots for an early 99?
For some reason when I clicked on the Ford tab the subcatagories didn't open.They do now
