Well u wont get any extra power but u can get a winsheild washer tank w/ pump out of a junk yard and run it in to ur exhaust and fill it with oil,atf,gas,lighter fluid, what ever u want lol and hook it to a switchl!!! Just be carefull with the mixture u make. Trust me it will smooooooooooke!!!!!!
for cold air intake go to NAPA and buy a 6637 (part number) filter. you will also need a 45 degree exhaust elbow and the required number of clamps. take the stock air box out and hook the filter and exhaust elbow to the stock pipe.
the 6637 isnt a cold air for say but i dont think cold air makes much diference on our trucks. Someone on hear compared under hood and ambient temps and they were fairly clos if i recall. A few guys will build boxes around the filter to block some heat of the motor. Thats what i'm looking to building a box when i get time
10K Deff. helps and its cheap and if u dont know what resistance to run on ur truck get the potentiometer or reostat at radio shack (also cheap) and u can vary the resistance u put to the ICP.
