Some misc issues
Old Dec 13, 2008 | 07:25 PM
farmert's Avatar
farmert
My 97 pulled when 2wd. When I pulled the axel shaft to check that ujoint I couldn't get the stub shaft to move. I had the long shaft in a vice and couldn't move the short one by hand.
Old Dec 13, 2008 | 08:31 PM
madpogue's Avatar
madpogue
Originally Posted by colorado solar guy
I have found that the LF joint is the first to go on a 50 axle.
Interesting; when my wife bought her PSD, it was the outer LF joint that was shot; not frozen, just waaaay wore out. Truck also pulled to the right, and that didn't change one bit with the u-joint replacement.
Edit: yeah, I can imagine a totally _frozen_ u-joint having an effect in 2WD. Even when the shaft isn't rotating, the joint still has to flex when you steer. I suppose if it freezes in a position other than "straight ahead", it would cause a pull.
ColoradoFordBoys
Ford Truck Parts for Sale
Oct 6, 2013 12:38 PM
colorado solar guy
Mar 21, 2009 05:48 PM
colorado solar guy
Jan 31, 2009 09:49 AM
colorado solar guy
Jan 11, 2009 01:33 PM
colorado solar guy
18
Sep 11, 2008 05:48 PM
