Foil Delete
Old Nov 13, 2008 | 10:18 PM
triskit16's Avatar
triskit16
Congrats. Hope it went pretty quick for ya with all the tips!
Old Nov 13, 2008 | 10:21 PM
krejci.mike's Avatar
krejci.mike
Before
After
Old Nov 13, 2008 | 10:25 PM
indebt's Avatar
indebt
cant see the pics Mike.
Old Nov 13, 2008 | 10:44 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by CSIPSD
And just an FYI because it always comes up... That foil has 0 to do with heat and everything to do with noise.
Oh Joe, how can you say zero to do with heat? I know, if that were the case, it would be on the cold side too. Wonder why that didn't happen? Thermal dynamics, or heat transfer says there is a benefit having the insulated foil no matter how little. Oh well, you say Turbonetics, I say tomato. Wait, aren't they the same thing?
Old Nov 14, 2008 | 10:16 AM
CSIPSD's Avatar
CSIPSD
Come on, you know better then that. There are several differant TSB's talking about adding a "updated drivers side IC pipe to control turbo noise". If it were for heat it would be on the cold side, not the hot side, as you said. At WOT the tube heats to 400 degrees or better with a stock turbo, much hotter then the engine bay.
Old Nov 14, 2008 | 11:18 AM
HH60FE's Avatar
HH60FE
Quick question (don't mean to hijack), but what the retorque on the boot bolts, or are they just tightened down enough to clamp?
Gona get this done this weekend. Too broke to do any upgrades.
Old Nov 14, 2008 | 12:48 PM
Mark250's Avatar
Mark250
What percentage more whistle would you say it gives you? I went the other way & put foil also on the pass side but might be reconsidering.
Old Nov 14, 2008 | 04:10 PM
Izzy351's Avatar
Izzy351
0% at the lower turbo RPMs, but at the higher RPMs, 100%! It also depends on whether or not you have a Wicked Wheel. There's a substantial increase in whistle with no foil, open style air filter, and WW. Mine went from barely audible to VERY cool...
EDIT: I like the non-painted look myself. Personally, I think the painted pipes are just too much under the hood. They stand out like two giant sore thumbs to me. But to each his own!!
Old Nov 14, 2008 | 06:08 PM
Steve_250's Avatar
Steve_250
What about using the hi-temp chrome/silver paint? Think that will help reflect the heat and not peel off?
Old Nov 14, 2008 | 09:09 PM
krejci.mike
I used a high temperature ford blue paint it seems to work but I have only had it on for a day
Old Nov 14, 2008 | 09:29 PM
krejci.mike
Before
After
now I have to paint the passenger side
Old Nov 14, 2008 | 09:42 PM
megawatt00's Avatar
megawatt00
Looks good Mike!!!
Old Nov 14, 2008 | 10:13 PM
  #28
mongo75's Avatar
mongo75
I actually used a propane torch to heat up the inside ofthe tube and that made it real easy to just pull off the foil and gunk in one shot, with minimal cleaning afterward.
robles4242
21
Sep 27, 2010 05:38 PM
crazer42
Jun 16, 2010 05:54 PM
crazer42
Jan 30, 2010 08:12 PM
Jbrown8988
May 9, 2009 04:51 PM
Adam0331
19
Aug 12, 2008 07:31 PM
