foil delete
Old Jan 30, 2010 | 05:29 PM
crazer42's Avatar
crazer42
foil delete
how do you do the foil delete, and what is the end result?
Old Jan 30, 2010 | 06:41 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
You get a lot of beer and summons up your patience. Pull and scrape the foil off. Then use several different solvents to remove the glue. The end result is a nice buzz and a piece of tubing that is without foil. It will look nice.
Old Jan 30, 2010 | 07:00 PM
Ponyboychris's Avatar
Ponyboychris
I used industrial paint remover from Home Depot. Two coats of the jelly stuff on the glue and off it came. Then some Scotch's Brite to shiner it up a bit. If anything, it gives your engine a nice clean finish.
Old Jan 30, 2010 | 07:19 PM
Izzy351's Avatar
Izzy351
Here's my thread from almost 3 years ago about it. HOLY CRAP!! Has it been that long already??? Wow....
https://www.ford-trucks.com/forums/5...nsulation.html
And the result is a cleaner install and a little mo' whistle.
Old Jan 30, 2010 | 07:25 PM
7.3 Rocket's Avatar
7.3 Rocket
I used:
Razor blade
Big ol gloves
Paint stripper
Plastic scraper/brush thing I found near the paint stripper at Lowes
Simple Green to remove any left over paint stripper off the pipe
Paper towels to use in conjunction w/Simple Green
Step 1: Pull IC pipe out of truck.
Step 2: Put on big ol gloves
Step 3: Slice foil and pull it away from the pipe.
Step 4: Cover entire pipe in paint stripper.
Step 5: Use scraper part to scrape away as much of the crud as you can.
Step 6: Go over entire part with brush to make sure it's nice and clean and you've gotten into all the crevices.
Step 7: Wipe off as much paint stripper as you can.
Step 8: Spray pipe w/Simple Green and wipe with paper towels until it's as clean as you'd like.
Step 9: Reinstall pipe on truck.
Step 10: Shut hood and dispose of crap you created during the project.
Old Jan 30, 2010 | 08:00 PM
Kajtek1's Avatar
Kajtek1
did all PS come with foil?
My 99 doesn't have it, there is no glue marks and I don't believe utility company who owned it before spend the time for cosmetics under the hood
Old Jan 30, 2010 | 08:12 PM
Izzy351's Avatar
Izzy351
No early 99s did...
dans 51 f2
Sep 12, 2015 05:35 AM
natewood75
Jan 15, 2010 09:39 AM
Jbru167
Mar 14, 2009 06:16 PM
griff64
13
Mar 3, 2008 04:05 PM
HJCartman
1978 - 1996 Big Bronco
Apr 1, 2006 09:42 PM
