Dash light replacement
Old Nov 9, 2008 | 07:40 AM
sorensenj's Avatar
sorensenj
2001 Ranger.
I have a burned out instrument cluster bulb that I need to replace. It's the bulb that lights up the gas gauge part of the cluster (farest left side one). Is there a way to change the bulb without taking the dash apart?
I'd like to have the bulb in hand before I start working on it. Does anyone know what number the bulb I need?
Thanks for any help
Jeff
Old Nov 9, 2008 | 08:17 AM
chief96's Avatar
chief96
Jeff,
Give this link a shot: https://www.ford-trucks.com/forums/3...ml#post2232781. I have been putting off replacing mine, it is a toss up between having Ford do it or the wife giving me permission to do it myself.
Old Nov 9, 2008 | 12:48 PM
Rockledge's Avatar
Rockledge
Check out: Replacing Ranger Instrument Cluster Lights
Old Nov 9, 2008 | 12:59 PM
Bear River's Avatar
Bear River
Former ******
Also, here is my suggestion for doing this right so you will never need to do it again.
Replace all the bulbs at the same time, and use LED bulbs, which also consume less power, last much longer, and produce less heat.
eBay Motors: 20 x 194 W5W White LED Wedge Inverted Side Bulb Light (item 190264033445 end time Nov-09-08 11:30:38 PST)
Old Nov 9, 2008 | 01:14 PM
azu's Avatar
azu
I waited until all but 2 were burnt out and replaced them all. If it is anything like the 2000 it shouldn't be hard. I was surprised how easy it was to do it and it took under 1.5 hours total. If I have to do it again it will take less than 30 minutes since I know how to do it now.
Old Nov 10, 2008 | 08:12 AM
sorensenj's Avatar
sorensenj
Thanks guys, maybe i'll wait awhile and see if anymore lights burn out I was hoping it wasn't a tear dash apart type job but looks like it is. I'll wait until warmer weather to spend some time working on it outside.
Jeff
BigRed1967
Oct 1, 2023 11:00 AM
rechinca
Sep 17, 2016 12:06 PM
buck_
Apr 25, 2016 07:50 PM
FordMan9707
Feb 4, 2015 02:56 PM
AllaboutMPG
Aug 2, 2014 10:57 AM
