Replacing gauge light bulbs:
Old Sep 29, 2009 | 01:20 AM
BigRed1967's Avatar
BigRed1967
I need to replace the light bulbs for my gauge cluster, speedo, tach, can someone tell me where these bulbs are located and how to change them, thanks very much.
bigred
Old Sep 29, 2009 | 07:33 AM
kadrocker's Avatar
kadrocker
I did this last year.
Reach yer arm under the dash and push a button behind the headlights **** to pop it out. Someone else will have to help you with the wiper **** as I forget how to get that one out. Then take out about 6 screws for the bezel. I think you have to take the radio bezel out too. Take screws out of gauge cluster and pull it out.
Be extremely carefull pulling the cluster out because the background is make of some fragile material that can (and will) turn to powdery dust. The bulbs are on the back of the gauge cluster. I think there are 7 bulbs total.
Someone correct me if I'm wrong. Don't wanna give wrong info out. Also tell him how to get the wiper **** out
Old Sep 29, 2009 | 10:57 AM
i-w's Avatar
i-w
i need to replace the left blinker dash light. it is out. thanks for the info hope it is similar on the 1979.
Old Sep 29, 2009 | 11:32 AM
Fordworth's Avatar
Fordworth
I just reach up and take out the bulb holder with out disassembling the whole dash. The bulbs are in little holders that plug into the back of the gauge housing and twist 90 degrees or so. Lay down on your back and look up in there with a light and you will see it.
Old Sep 29, 2009 | 12:10 PM
BigRed1967's Avatar
BigRed1967
Thumbs up Dash Lights:
Thanks for the replies folks, this is such a great site; everyone helps out each other, I appreciate the help very much.
thank you
Bigred
Old Sep 29, 2009 | 01:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Each bulb fits into a plastic socket that twists into the instrument panel's cluster back.
You do NOT have to remove the instrument cluster to replace bulbs!
Just reach back there and remove the sockets. You do not want to remove the instrument cluster, because...
The cluster backs used on trucks of this vintage (1975/79) were made from a composition material that could...and did...turn to DUST before your very eyes!
Ford replaced these fracatta cluster backs in 1981 with the hard plastic cluster backs used in 1981/86 (idiot lights) & 1981/91 (all gauges) Econolines.
Some of these cluster backs have since been replaced with the hard plastic types, most have not been replaced.
E1PZ10848A .. Cluster Back, use with all gauges: Fits: 1975/91 Econoline, 1975/79 F100/350, 1978/79 Bronco.
E1PZ10848B .. Cluster Back, use with warning (idiot) lights: Fits: 1975/86 Econoline, 1975/79 F100/350, 1978/79 Bronco.
These two cluster backs are now obsolete. Green Sales Co. (800-543-4959) in Cincinnati OH & Dennis Carpenter (704-786-8139) in Concord NC have Gen-U-Ine NOS Ford originals.
And...there are 1000's of 1981/91 Econolines in wrecking yards.
Old Sep 29, 2009 | 02:19 PM
i-w's Avatar
i-w
WoW you impress me everytime you post... AWESOME. thanks
Old Sep 29, 2009 | 06:10 PM
shadowviper12345's Avatar
shadowviper12345
what is the part number for the sockets themselves. 79 f100.
Old Sep 30, 2009 | 01:29 AM
NumberDummy
F4UZ13B765A (replaced: C8OZ13711B & C8OZ13711A) .. Instrument Panel Lamp (Bulb) Socket / Available from Ford
Fits: 1970/96 F100/350 / 1968/96 Bronco / 1970/2003 Econoline / 1997/98 F(Super Duty).
Fits: 1968/70 Fairlane/Torino/Falcon/Montego/Comet / 1971/79 LTD/Mercury Marquis/Fairlane/Torino/Montego/LTD II/Mustang/Cougar/Pinto/Maverick/Comet/T-Bird/Lincoln/Mark III/Mark IV/Mark V.
Fits: 1980/91 Crown Vic/Mercury Grand Marquis/Lincoln Town Car and other misc 1980 and later Passenger Cars.
MSRP each: $1.85 // FTE sponsor Y2KFORDPARTS.COM price each: $1.33.
Old Mar 18, 2016 | 06:49 AM
tripper2's Avatar
tripper2
Is there a way to tighten dash light sockets on a F150 1978 cluster?
Old Mar 18, 2016 | 09:35 AM
HoustonDave's Avatar
HoustonDave
It's a standard 194 bulb socket - this is the kind with wire contacts at the base, like our side running lights. Not much you can do to tighten those contacts, but they rarely go bad. The contacts from the socket to the printer circuit sheet are simple brass alloy arms which can me bent up from the socket to make better contact. A little scrubbing of the area on the circuit sheet they contact would not hurt, either.
Small adder to the cluster removal - you will also have to remove the speedo cable (by squeezing the white retainer clip around it and pulling the cable from the cluster, and removing the gang electrical plug from the cluster which has two locking latches, one at either short end. They ae a pain. If you can reach the bulbs from below, that may be far easier unless you just really want to pull the cluster or can't reach the bulbs.
Wiper **** is held on by a small flat spring around the shaft - if you push the part of the spring closest to the dash face toward the ****, you can work the **** loose. Probably need a flashlight and a small screwdriver or hook - takes longer to describe than to do.
Old Sep 27, 2023 | 08:50 PM
Mohaw73's Avatar
Mohaw73
1st Gear
Replaced now half won't work
I just changed my bulbs out and only half of my bulbs are working do I need to replace that circuit board on the back now?
bigred
Old Sep 27, 2023 | 10:38 PM
cb_13's Avatar
cb_13
I’d start by checking the printed circuit board. If it’s got some material wore away where the bulb sockets make connection you can repair that with defrost grid repair paint or you can just replace the circuit board.
Old Sep 28, 2023 | 06:31 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Did you use LED's? You know they are a directionally required bulb, meaning they only work installed in one way or direction.
Some times easier to have a person watch that unlit area, while you lay under there and remove and reinstall the bulbs. You just might not of made a good contact when you installed the bulb. Once you get the bulb out, insp it real for bent or misaligned contact's. Then reinstall very carefully, it is not a screw way in type bulb. You helper hollers when it is working.
Also if you do go to replace the printed circuit board, when you go to take the nuts off the mount studs on the gauges. DO NOT LET THE STUDS BREAK LOOSE. Meaning hold to the end of the stud with some needle nose pliers while you use a small wrench to break loose the nuts. Same for tightening them.
Might get away with some copper repair tape on the circuit board, before you 100% replace it.
Amazon Amazon
If you do have to pull the instrument cluster, here you go.
https://www.ford-trucks.com/forums/1...l#post14880899
Or https://www.ford-trucks.com/forums/1...l#post14982704
Old Oct 1, 2023 | 11:00 AM
Westcoast Highboy's Avatar
Westcoast Highboy
I had the disintegrating rear cluster body issue and after trying to repair it, gave up and replaced it with a new one from Dennis Carpenter.
Initially installed led bulbs which worked great and were nice and bright for about a week before they began to flicker which drove me crazy.
Went back to standard 194 bulbs and no problems since.
kadrocker
16
Apr 19, 2009 02:57 PM
arcatek
Apr 21, 2007 07:13 PM
neufelda
1983 - 2012 Ranger & B-Series
Mar 31, 2004 08:21 AM
Big
Apr 7, 2002 08:15 PM
