Only one Dash / Instrument Panel light not working
Old Sep 17, 2016 | 07:55 AM
rechinca's Avatar
rechinca
I have only one light bulb in the dash cluster that will not light up. The headlight switch was replaced due to corrosion and that cleared up the intermittent lighting issue, but not this problem.
The bulb is in the top right corner and lights up the Oil Pressure and Temp reading gauges. (Yes this one has the full gauge package). All of my other lights work properly with the exception of the one bulb. The housing for that bulb was cracked to I replaced it with a spare I had laying around and even put in a new bulb with no change.
Is it possible there is a crack in the printed circuit board before it reaches that light? I thought the path of electrical flow started at this bulb and worked its way around the board, but maybe I am mistaken on that and I need to trace around the board and see if their is a break in the line before it reaches that bulb? Any help would be greatly appreciated.
Old Sep 17, 2016 | 08:21 AM
orich's Avatar
orich
Have to tried cleaning the circuit where it makes contact. Pencil eraser works pretty good cleaning any corrosion from the surface of contact.
Orich
Old Sep 17, 2016 | 12:06 PM
rechinca's Avatar
rechinca
Orich I will give that a try tomorrow, can't work on the truck when college football is on!
R&T Babich
Oct 24, 2018 11:36 PM
rlzegers
Jul 19, 2017 10:30 AM
FordBoy2012
Jan 16, 2016 10:52 PM
Ryank78shortbed
May 2, 2011 05:10 AM
Dalef250
Mar 26, 2011 08:25 AM
