Difference in Cam Position Sensors?
Old Nov 10, 2008 | 06:45 AM
tjbeggs's Avatar
tjbeggs
Old Nov 10, 2008 | 02:49 PM
GWF3507.3's Avatar
GWF3507.3
As usual a wealth of knowledge on here. Thanks for pointing it out.
Old Nov 11, 2008 | 08:48 PM
SaintITC's Avatar
SaintITC
I read in ForemanES's reply how his grey CPS "only hiccupped once". What do you mean by hiccup? My '97 PS has recently in the last few days hiccupped while pulling away from a light or up a hill (is there such a a thing as a load on an empty 7.3L PS?). Having no clue as to what may be causing this, I searched for "hiccup". Anyway, can the CPS fail intermittently like this?
Old Nov 11, 2008 | 09:05 PM
ron86toy's Avatar
ron86toy
yup...get ready to replace...If you have not had the recall done yet go to the dealer and have it done for free......but pick up an extra to throw in the glovebox
mine hiccuped twice then a mile down the road I was calling for tools
Old Nov 11, 2008 | 09:16 PM
SaintITC's Avatar
SaintITC
Ron, Thanks for the advice. When I bought the truck, a friend was a service manager at a dealership, he checked the VIN and all the service and recalls had been performed (which is why I flew 1600 miles to buy it on ebay)
Old Nov 11, 2008 | 10:21 PM
KC92F150's Avatar
KC92F150
I just had the recall done on my 97 F-350 today.
According to the invoice the CPS P/N is F7TZ 12K073 and it cost $17.40, labor was $26.89, totaling $44.29
Now this didn't cost me anything because it was done under the recall.
After reading through this thread, I am wondering if this CPS is a POS. I guess time will tell.
I think I should go and get a spare like everyone suggests.
Kevin
Old Nov 11, 2008 | 10:30 PM
952X4's Avatar
952X4
I'm going to check and see if my truck has had a recall or not. I bought a spare CPS and will always carry a spare from now on..
Old Nov 11, 2008 | 10:32 PM
SaintITC's Avatar
SaintITC
Does anyone know the recall number or whatever it is to have the dealer check? Sometimes it's helpful to know exactly what you're looking for when you come in.
Old Nov 11, 2008 | 10:37 PM
SaintITC's Avatar
SaintITC
Ok, I'll answer that one myself. Went to:
Recall Information - Ford
entered my info and found:
Recall: 07S57
Description: CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
Old Nov 11, 2008 | 10:45 PM
KC92F150's Avatar
KC92F150
SaintITC, the recall number is 07S57. Hope this helps.
Kevin
Old Nov 12, 2008 | 08:59 AM
ron86toy's Avatar
ron86toy
It is only for the '97 and newer 7.3.......sorry about that
Old Nov 12, 2008 | 01:40 PM
F-350PSD's Avatar
F-350PSD
ok so I've decided I need to get a spare even though I just had my recall performed. Only one problem: how do you install these?
Old Nov 12, 2008 | 02:05 PM
  #28
Neal 97 250's Avatar
Neal 97 250
If you are looking at the front of your block. It will be in about the 10 o'clock position from the crank pulley. It is best accessed from under the truck. It will take a 10 mm and a short extension w/ratchet to get it off. I use a 1/4" drive ratchet and a deep well socket. You may need a screwdriver to pry it out after you remove the hold down bolt.
Clean the contacts on the plug and replace.
Takes maybe 10 minutes.
Old Nov 12, 2008 | 03:11 PM
  #29
ron86toy's Avatar
ron86toy
What Neal said.....I keep a gear wrench in the glove box and I always have a leatherman in the truck too.
Oldanvilyoungsmith
Sep 28, 2016 12:08 PM
DuncanCloud
Dec 19, 2015 09:03 AM
Nader
23
Oct 8, 2015 08:12 AM
helgaairhead
Feb 7, 2014 06:04 PM
ford_muddbilly81
Apr 21, 2009 10:57 PM
