what are these codes?
Old Oct 26, 2008 | 03:02 PM
glasseater's Avatar
glasseater
hey guys just did a buzz and cyl contribution test and got these codes:
buzz: P1111
Cyl Contribution: P0196
other codes that were stored:
P0113
P0478
P1211
thanks guys
Old Oct 26, 2008 | 03:27 PM
BlueMule's Avatar
BlueMule
buzz: P1111
P0113
P0478
P1211
thanks guys
p1111 passed buzz test
p0196 unable to run cct because engine was not up to temp
p0113 ait circuit out of range
p0478 ebp sensor high
p1211 icp out of range high/low
Old Oct 26, 2008 | 03:29 PM
tjbeggs's Avatar
tjbeggs
P1111 is a pass code. It means the test ran but no codes found
P0196 EOT EOT sensor ckt performance (96 MY) Aborts KOER CCT test Engine not up to operating temp., leaking thermostat
P0113 IAT Intake air temp sensor ckt high input Defaults to 15°C Open circuit, biased sensor, PCM, short to 5V
P0478 EPR Exhst press control valve high input Excessive back pressure - run mode Plugged sensor line, stuck butterfly, restricted exhaust
P1211* IPR ICP pressure above/below desired Continuous and KOER on-demand test IPR valve failed, stuck, or shorted to ground
Don't worry about the 1211 as you already know your injectors and chip over tax the HPOP
The 478 might be a plugged line to the sensor, unplugged sensor and bad sensor
the 113 could be a bad sensor or unplugged
The 196 probably means you tried to run the Contribution test without the engine being warmed up.
glasseater's Avatar
glasseater
would these basically be overboost codes??
thanks bluemule
tjbeggs's Avatar
tjbeggs
Rodney is too fast!!
Old Oct 26, 2008 | 03:34 PM
glasseater's Avatar
glasseater
thanks tim, i have my ebpv unplugged so i'm guessing that would throw the one code, and of course my chip taxing the HPOP, even though it si a 17* pump, and my truck was not warmed up when i did the cyl contr. test
Old Oct 26, 2008 | 03:42 PM
BlueMule's Avatar
BlueMule
I don't think so Tim.
I started 1st and did the short version while you explained each code.
Old Oct 26, 2008 | 08:55 PM
c00nhunterjoe's Avatar
c00nhunterjoe
no, not overboost codes.
fixitman1310
Jun 6, 2010 10:13 AM
Farmboypowerstroke
Mar 12, 2010 09:13 PM
damicofuel
Dec 18, 2009 08:17 AM
Krupka
Mar 16, 2008 10:47 PM
Hiflyer746
Dec 9, 2007 10:44 PM
