P1111 is a pass code. It means the test ran but no codes found
P0196 EOT EOT sensor ckt performance (96 MY) Aborts KOER CCT test Engine not up to operating temp., leaking thermostat
P0113 IAT Intake air temp sensor ckt high input Defaults to 15°C Open circuit, biased sensor, PCM, short to 5V
P0478 EPR Exhst press control valve high input Excessive back pressure - run mode Plugged sensor line, stuck butterfly, restricted exhaust
P1211* IPR ICP pressure above/below desired Continuous and KOER on-demand test IPR valve failed, stuck, or shorted to ground
Don't worry about the 1211 as you already know your injectors and chip over tax the HPOP
The 478 might be a plugged line to the sensor, unplugged sensor and bad sensor
the 113 could be a bad sensor or unplugged
The 196 probably means you tried to run the Contribution test without the engine being warmed up.
thanks tim, i have my ebpv unplugged so i'm guessing that would throw the one code, and of course my chip taxing the HPOP, even though it si a 17* pump, and my truck was not warmed up when i did the cyl contr. test
