P1272 P0266
Old Dec 8, 2007 | 06:11 PM
Hiflyer746's Avatar
Hiflyer746
P1272 P0266
My buddies 97 is running rough. Now I know I should be in the OBS section. . . nothing wrong with that section but you guys are family
Anyway, it sounds like its missing a cylinder. . . or most of one. I pulled these two codes after a contribution test and a buzz test. P1272 states Cylinder #2 High to Low side open. English? During the buzz test the Number two injector is quite noticeably quieter. Contribution test gives the P0266 which states Cylinder 2 injector circuit contribution/balance fault.
Whats everybody thinkin? I'm thinking pull the valve cover and make sure the connection is good. . . and if it is then I'm thinking we just have a poor injector. However, I'm worried it could be in the IDM or somewhere else. Let me know what you guys think. Thanks guys! Oh and not to get all teary or nothing. . but I love you guys!
Tim
Old Dec 8, 2007 | 06:13 PM
Hiflyer746's Avatar
Hiflyer746
Also I'm getting a P0470 for exhaust pressure sensor. At idle the sensor is reading almost 53 PSI. i know thats not right.
Tim
Old Dec 8, 2007 | 07:14 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
id say pull those VC off and check it out first before you go nuts. than change the ebps cause thats what gives you the reading of 53psi, did you ever check you tube if its cloged? mine was solid like rock inside.
Old Dec 9, 2007 | 11:37 AM
Hiflyer746's Avatar
Hiflyer746
Yeah I guess that would be the logical solution But its so cold outside!!! I'll give a followup soon.Tim
Old Dec 9, 2007 | 12:14 PM
PETE'S_6.0PSD
i know cold wether does not help for sure, fingers dont want to work like they should. But i would do it as soon as you guys can cause that cylinder not working properly can only cause more problems down the road.
Old Dec 9, 2007 | 06:01 PM
Hiflyer746's Avatar
Hiflyer746
Yeah its gotten freakin cold here. Thats why I've been insulating and drywalling my garage. However. . . the ceiling just sucks.
Tim
Old Dec 9, 2007 | 06:53 PM
PETE'S_6.0PSD
i know it does. i did it long time ago with the fiberglass insulation. what a PITA.
Old Dec 9, 2007 | 10:44 PM
Hiflyer746's Avatar
Hiflyer746
Well I rented a drywall lift today from the depot and I got almost 2/3 of the ceiling done. I'm so excited about that. Now I have to move all the crap from one side to the other so i can use the lift
Tim
foul1
Aug 27, 2022 04:22 PM
davidlea
Dec 8, 2011 08:45 PM
mrblonde108
Sep 19, 2010 12:11 PM
Farmboypowerstroke
Mar 12, 2010 09:13 PM
strokin'_tatsch
Nov 12, 2009 09:32 PM
