CCV Mod
Old Sep 19, 2008 | 03:51 AM
ron's power stroke's Avatar
ron's power stroke
Originally Posted by greedy737
don't mean to If I want to replace the orings under the dog house, what size orings do I get?
there a beveled oring...dealer item..they where only 10 bucks for the set....
Old Sep 19, 2008 | 05:55 AM
Chuck U&R's Avatar
Chuck U&R
I just did this mod but -
instead of going over the mstr cyl I just went down about 45* and back
instead of using a new piece of 4" pipe I used the original fitting, cut out
the 'hood' and plugged the hole.
Did I mess up ??????
Old Sep 19, 2008 | 06:28 AM
greedy737's Avatar
greedy737
The reason you run the hose up hill over the master cyl. and than down, is to give any oil that maybe blown in there a chance to run back into the dog house, instead of dripping on the ground. But I know of others that did it the sameway you did with no problems! Also as its ok to cut the hood piece out and plug the hole in the plastic connector, aslong as the plug don't come lose an get sucked into the turbo or suck dirty air in there past the plug! Its just alittle easyer using a 4" pipe!
Old Sep 19, 2008 | 03:52 PM
greedy737's Avatar
greedy737
Thank you Ron, I was hoping a regular oring from NAPA would work! I know they have thin and thick ones in different sizes..
Bigtruc
26
Jan 1, 2013 07:47 PM
tdpower
34
Jan 25, 2010 07:20 PM
fishernoiter
Apr 3, 2009 12:38 PM
tndiesel
20
Mar 11, 2009 03:24 PM
pushingxthexedge
Mar 12, 2008 11:00 PM
