View Poll Results: How many injectors to replace
Just the bad one.
24.00%
All the ones on that bank
0%
All 8
16
64.00%
I have no clue
12.00%
Voters: 25. You may not vote on this poll
How many injectors do I need
Old Aug 15, 2008 | 04:26 PM
F350-6's Avatar
F350-6
Originally Posted by cleatus12r
This is quoted from Dave at Swamps....
........"and the truck has around 175,000 miles on it, then the poppet valves are probably shot.
when the oil gets hot (and thin) a worn poppet valve, even on only one injector, can & will cause low oil pressure (ICP) to ALL of the injectors, as that one worn poppet valve can **** enough oil back into the valve covers to drop the entire system pressure.
If the truck runs good while cold, and runs like crap when hot, then that is textbook poppet valve wear, and an indication that the injectors need new poppet seats cut, and new (poppet) valves lapped...very similar to a valve job on a cylinder head."
With 170K, you may as well do all 8. I have seen first hand what happens with worn out injectors.
Thanks cleatus. I've seen that info from Dave before. That truck happens to be the lowest mileage 7.3 I have, and it's the one that got a bad injector. The others, including mine at 260k, are still running the factory sticks.
ford1341
Mar 20, 2014 06:41 AM
1983/84f350
Mar 22, 2012 08:15 AM
wescon
Jan 26, 2012 06:50 PM
Jaaaaaaackman
25
May 22, 2011 09:28 AM
StillaKilla187
26
Mar 4, 2007 06:51 AM
