View Poll Results: How many injectors to replace
Just the bad one.
24.00%
All the ones on that bank
0%
All 8
16
64.00%
I have no clue
12.00%
Voters: 25. You may not vote on this poll
How many injectors do I need
Old Aug 15, 2008 | 09:03 AM
F350-6's Avatar
F350-6
Time to replace the #4 injector on one of the work trucks. 02 350 with 170k on the odometer. So what's the opinion of everyone here?
Old Aug 15, 2008 | 09:20 AM
indebt's Avatar
indebt
All 8 , Go In Once And Be Done For Another 170k.
Old Aug 15, 2008 | 09:22 AM
jdecker88's Avatar
jdecker88
I agree with Jorge just replace them all if you have the money and be done with it. Hows your truck running after you dove into her?
Old Aug 15, 2008 | 10:04 AM
sneak's Avatar
sneak
I'm kind of half way in between here being that it is a work truck and you need it to make money... but I put my vote down for one injector.
Old Aug 15, 2008 | 10:27 AM
totin_tools's Avatar
totin_tools
I have replaced one ijector at a time. Now I think I have 3 or 4 new ones and the rest are stock. I know next time I will just get some aftermarket ones and forget this thing of one at a time.
Old Aug 15, 2008 | 10:49 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I think you need nine injectors. One stock one for your work truck, and eight hybrids for mine.
Old Aug 15, 2008 | 01:37 PM
bigsteve1969's Avatar
bigsteve1969
ha ha make that 18 injectors ha ha but seriously i would go with all 8!
Old Aug 15, 2008 | 01:45 PM
parkland's Avatar
parkland
All 8 if it can be afforded,
replacing injectors 1 at a time will undoubedly cost more in the long run,
however not everyone has 2500$ do drop on injectors.
Old Aug 15, 2008 | 03:06 PM
Kwikkordead's Avatar
Kwikkordead
Is the rest of the truck trashed because it is a work truck?
I voted all eight, but if the truck is going to be traded off in less than two years due to amortization, then just pinch the pennies and get the one - cheap.
Old Aug 15, 2008 | 03:27 PM
F350-6's Avatar
F350-6
The truck is in pretty good condition. It's a flat bed so no issues with the bed being dinged up. The truck is already off the books, so no amortization issues. I'm not fond of the 6.4 and will have to wait and see what the next motor brings. The risky side is the truck is driven by an employee, and people don't tend to treat company trucks as well as they treat their own.
Old Aug 15, 2008 | 03:38 PM
stangclassic66's Avatar
stangclassic66
Can International Powerstroke injectors be pop tested? I would NOT get all 8 if they can be pressure pop tested. Waste of money if you ask me. If they can be pop tested, pull all of them and take them to a reputable diesel injection shop. Then get them rebuilt, if they can be rebuilt.
In my marine diesels, 6bt cummins and volvo diesels, I can pull each injector and get them all tested and/or rebuilt. Rebuilding is much much cheaper than buying new. Cost me $80 per injector vs. $300 for new.
Old Aug 15, 2008 | 03:40 PM
stangclassic66
Now would be a good time to check your fuel filtration as well.
Old Aug 15, 2008 | 03:43 PM
F350-6's Avatar
F350-6
Fuel filter was fine, no signs of oil in the bowl or degas bottle.
Old Aug 15, 2008 | 04:03 PM
stangclassic66
I called my diesel shop myself and I will stand corrected. Powerstroke injectors cannot be reliably pop tested (false readings). They can, but they have to be taken apart, cleaned, then put back together, and after that's all said and done, it could have just been rebuilt. Doesn't make any sense.
$225 rebuilt
$275 new are the prices I was quoted.
Old Aug 15, 2008 | 04:12 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
This is quoted from Dave at Swamps....
........"and the truck has around 175,000 miles on it, then the poppet valves are probably shot.
when the oil gets hot (and thin) a worn poppet valve, even on only one injector, can & will cause low oil pressure (ICP) to ALL of the injectors, as that one worn poppet valve can **** enough oil back into the valve covers to drop the entire system pressure.
If the truck runs good while cold, and runs like crap when hot, then that is textbook poppet valve wear, and an indication that the injectors need new poppet seats cut, and new (poppet) valves lapped...very similar to a valve job on a cylinder head."
With 170K, you may as well do all 8. I have seen first hand what happens with worn out injectors.
