Auto transmission Help!
Old Aug 7, 2008 | 12:02 AM
jongirouard's Avatar
jongirouard
Question Auto transmission Help!
My transmission downshifts from 3rd gear to second and then right back to third gear when low acceleration through town. upon heavy acceleration on highway,no downshifting effects..shifts regularly..
Any advice would be very much appreciated.
jon
Old Aug 7, 2008 | 08:50 AM
royzell's Avatar
royzell
What year, engine, tranny and truck ?
Old Aug 7, 2008 | 12:13 PM
jongirouard
I have a 1990 F250 7.3 non turbo, I really don't know what kind of transmission, how can i find that out? I think it is a 4 speed auto with overdrive..
thanks for your reply.
Old Aug 7, 2008 | 12:55 PM
royzell's Avatar
royzell
It is likely an E40D. I don't know anything about those, perhaps someone else will jump in.
I would also suggest searching this site (IDI) and the Transmission site for related threads.
Old Aug 7, 2008 | 01:04 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is an E4OD. Most likely you have a FIPL sensor going out. It's the sensor on the injection pump.
Old Aug 7, 2008 | 01:29 PM
tradergem's Avatar
tradergem
Get or borrow or rent a OBD1 code reader and read the diagnostic codes from the transmission control computer. These will tell you the most likely problems you are having. It sounds harder than it actually is. Just follow the test instructions exactly step by step and you will be able to read the codes no problem.
Jim
Old Aug 7, 2008 | 06:11 PM
snubber's Avatar
snubber
Maybe the link below can help??
https://www.ford-trucks.com/forums/6...d-problem.html
Old Aug 7, 2008 | 09:07 PM
jongirouard
thanks folks, great info to get started with..
jon
Old Aug 12, 2008 | 11:02 PM
ford trans tech's Avatar
ford trans tech
note , anytime you perform a test on this vehicle with a code reader you must hold the throttle at the wide open setting before initializing the tester or you will recieve a false code for the fipl , (tp) sensor
example , a pass would be 11-10-11 if you do not hold the throttle open you will receive
a 23-10-11 the first number is for a hard fault code the 10 is the seperator code after that any code is a memory code so 23 -10- 43 would be a hard fault fipl seperator and a memory code for the fipl
Old Aug 13, 2008 | 03:13 PM
jongirouard
thank you very much for this tip!
Old Aug 13, 2008 | 03:29 PM
nicebenz68's Avatar
nicebenz68
I had the same problem with both of my trucks with different causes. My 93 shifting issue was a vehicle speed sensor, which is a cheap and easy fix. This problem also periodically causes the speedometer to be unstable. Speed sensor is available at Autozone. My 91 shifting issue was caused by the TPS (sensor which all above have mentioned) on the injection pump needing adjustment.
These are the only two issues externally which will cause the problem you mention.
Andy
SomeoneTV
Sep 16, 2012 10:12 AM
jimbofug
1983 - 2012 Ranger & B-Series
Nov 30, 2010 05:51 PM
clockweights
1997 - 2003 F150
Jun 5, 2006 12:11 PM
override
Dec 19, 2005 09:54 PM
bigdieseldav
Dec 18, 2003 07:01 AM
