possible trans or tc
Old Nov 29, 2010 | 08:54 AM
jimbofug's Avatar
jimbofug
ok im driving down the road and ill slightly push the gas to accelerate some to pass and my truck downshifts were before i could accelerate in 5th gear without it downshifting. but it never had downshifted when i barely pushed the pedal down. im confused by this. and if this helps it is slow to engage into drive when i shift it. trans fluid is pink mostly smells ok any thoughts or ideas?
Old Nov 29, 2010 | 06:11 PM
cj06's Avatar
cj06
what year is the truck , and what engine and tranny do you have ? more info the better for some one to help !
Old Nov 29, 2010 | 10:58 PM
jimbofug's Avatar
jimbofug
its a 2000 ranger with a 3.0 im not sure of the trans id have to check that ill have that up soon its raining
Old Nov 29, 2010 | 11:12 PM
cj06's Avatar
cj06
HERES SOME GOOD INFO !
Common Fix For 4r55e / 5r55e Transmissions With A Bad Separator Plate And Valve Body Gasket .: Articles
Old Nov 29, 2010 | 11:14 PM
g_k50's Avatar
g_k50
Sounds like it's more likely to be the trans. Try not using overdrive. Only use overdrive while cruising, not for accelerating.
Old Nov 30, 2010 | 05:30 PM
jimbofug's Avatar
jimbofug
well thats wht i do its an automatic trans and it for the most part it has a mind of its own it seems tho as i push the gas sometimes i can tell when the tc locks and wont down shift but then theres others were im just normal driving and it will down shift at the slight change of the pedal
Old Nov 30, 2010 | 05:51 PM
jimbofug's Avatar
jimbofug
its a 4r44e trans
kmeifert
1997 - 2003 F150
76
Dec 16, 2023 09:37 PM
gandrimp
Large Truck
Aug 27, 2013 10:02 PM
F TOO FITTY
2009 - 2014 F150
24
Jan 2, 2013 09:39 PM
SUPERDUTY OUTLAW
Mar 7, 2011 07:17 PM
teamjlp
Dec 30, 2002 08:31 AM
