tach trouble
Old Jun 28, 2008 | 01:16 PM
speed demon's Avatar
speed demon
tach trouble
iv got a 65 ford.not sure what the motors out of but the best iv found so far is its a 289 thats out of something in the 67s.iv tried to hook it up like normal bu t it wont work.iv even tried a differant tach.is there something with the points styl thats dif or is there just some thing im not seeing.id realy like to have a tach.pleas help
Old Jun 28, 2008 | 03:11 PM
flipklos's Avatar
flipklos
negitive side of the coil.-Green wire
switched Positive.-red wire
ground.-black wire.
Sould work.
Find out what motor you have. More Info is generaly better than less. 289's never came in a pickup to my knowledge and 302's not till later in the 70's
Old Jun 28, 2008 | 11:46 PM
speed demon
thats just it.i have it hooked up that way and it still dont work.would it have anything to do with the points system.
Old Jun 29, 2008 | 12:41 AM
bigblockford_390's Avatar
bigblockford_390
If the engine runs and you hooked the tach up as stated by a preivous post then my guess is you have a tach problem. If the engine runs that means the coil is operating correctly. I would double check you are on the right terminal on the coil, the same side as the wire that goes to the distrubutor. And I would check that you have a good ground. All electronics need a good ground.
Does the tach not do anything or just displays the incorrect reading?
Red wire to switched power
Green wire to negative on the coil
Black to a known good ground
White to a light switch to turn on the light in the tach.
It makes no differance the brand or size of the engine when installing a tach. They work on 4, 6, and 8 cylinder engines by hooking up as listed above. The only change to that is new engines with out distributors and then there are changes. But as long as it was a single coil fired engine points or electronic ignition no change in the wiring. There is a switch inside the tach to select the number of cylinders from 4 to 6 to 8.
Jeff
Old Jun 29, 2008 | 01:17 AM
speed demon
the ground might b it cus thes the 1 thing i havnt checked.the tach doesnt read at all
GM4WALLS
13
Jul 14, 2021 10:26 PM
93nighthawk
Aerostar
39
Sep 23, 2015 08:55 PM
Macs1964F100
Jul 13, 2014 07:31 PM
wayneF250
Oct 14, 2007 08:49 PM
67f100
Nov 15, 2005 04:43 PM
