fuel removal
Old Nov 11, 2005 | 08:06 AM
67f100's Avatar
67f100
fuel removal
Iv'e got a 74 parts rig that will be going to the junk yard soon. It has two tanks nearly full of gas. Iv'e tried getting it out with a siphon pump that I have but no luck. Is there a screen or flap of some sort thats blocking it? With gas prices the way they are I dont want to send it all to the bone yard.
Old Nov 11, 2005 | 08:35 AM
Edberg's Avatar
Edberg
Hey Bud
Also if they know they are full they will deduct some because of Flammable liquid. There should be a hose right by the cap so fuel can run off into the tank disconnect that. and try to siphon it with a piece of garden hose. Or poke a hole in the tank be carful make one spark and big Mistake that will be.
Good Luck Buddy
Edberg
Old Nov 11, 2005 | 02:29 PM
qman's Avatar
qman
No, there's no flap in the way. Just get some hose and siphon. I did it when I changed out my tank and it was easy.
Old Nov 11, 2005 | 11:17 PM
Hypoid's Avatar
Hypoid
I just unhook the fuel line at the pump. It sits lower than the tank, already has siphon going for it.
Same idea should work for your tanks. If the line has lost it's siphon, put a LITTLE air pressure on the top of the fuel through the filler neck.
Old Nov 15, 2005 | 12:08 PM
qman's Avatar
qman
that's a great idea. I couldn't do that though cause my fuel line was plugged due to a rusted out tank and I had to get the fuel out to replace the tank.
Old Nov 15, 2005 | 04:43 PM
thesprocket26's Avatar
thesprocket26
If you have an electric inline fuel pump, wire that up and run the hose into a tank you will be using. Dropping a full tank isn't fun. I squished little me and luckily didn't spill.
steve454
Electrical Systems/Wiring
Jul 1, 2016 10:55 AM
James Spearman
May 19, 2016 03:22 AM
otpracer
Jan 21, 2012 09:02 PM
underp2
Dec 3, 2003 08:33 PM
phreakfree
Jan 16, 2003 08:38 PM
