Pre-65 FE Motor Mounts
Old Jun 28, 2008 | 02:35 PM
ricky berry's Avatar
ricky berry
I'll try to post here,maybe my issue will get greater visibility....send the cavalry !!!
Ok! Guys! Here I go...We just pulled my 352/360 block from my '65 SWB,1/2 ton pick'em up truck. The block has a cracked water jacket. This block also has four motor mount holes, 2 large ones( approx. 5" on center) and 2 small ones (approx. 3" on center). My replacement block has only the 2 smaller bolt holes. My question is : what motor mounts/ hardware will allow me to
mount this early FE block in my '65 P/U,originally designed to accept the larger mounts/hardware ? Will this smaller mount allow us to use the stock exhaust manifolds? Any advice will be muchly appreciated.
Old Jun 28, 2008 | 03:02 PM
flipklos's Avatar
flipklos
Im not 100% on this but the block you pulled out with the four bolts I think is an FT heavy duty truck engine. I read somewhere that they had 4 bolt motor mounts. Also, not totaly sure but aint the 2 bolt FE mounts are from the late 50's and very early 60's. any one sould mount in there without fab.
Good luck.
Old Jun 28, 2008 | 03:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ricky berry
Ok! Guys! Here I go...We just pulled my 352/360 block from my '65 SWB, 1/2 ton pick'em up truck. The block has a cracked water jacket.
This block also has four motor mount holes, 2 large ones (approx. 5" on center) and 2 small ones (approx. 3" on center).
1965/71 passenger car or 1965/76 F Series truck FE block.
My replacement block has only the 2 smaller bolt holes. 1958/64 passenger car FE block
My question is: What motor mounts/ hardware will allow me to mount this early FE block in my '65 P/U, originally designed to accept the larger mounts/hardware?
Welcome to FTE
Two bolt holes: You have a 1958/64 FE engine from a car, which uses different motor mounts.
First year for an FE engine to be factory installed in an F Series truck: 1965.
AFAIK, you'll have to fab some steel brackets to allow the FE rubber mounts to bolt to the early 1958/64 engine block.
Mebbe some aftermarket supplier offers them, but Ford does not.
Old Jun 28, 2008 | 05:07 PM
ricky berry
Thanks guys for the info...I'll search the web and see what I can come up with. This engine has roughly a 4" stroke with roughly a 4-1/16" bore...Hmm! That calculates to a real high fun factor...I'll let you know what I come up with.
Old Jun 29, 2008 | 12:31 PM
flipklos's Avatar
flipklos
sounds like a mercury 410. Thats about the best towing motor around. Have fun with that tire smoker.
Old Jun 29, 2008 | 02:07 PM
NumberDummy
With only two motor mount holes per side, there is absolutely no way the block can be any newer than 1964. 410's were used 1966/67.
1965 and later FE engine blocks can be used in any car or truck. Not so prior to 1965.
With a B&S that size (if correct), the engine been bored & stroked to the absolute max.
I'd have that block magnafluxed first before doing anything else with it.
The two largest FE engines available pre 1966 were the 427: 4.23" x 3.78" / and the 406: 4.13" x 3.78"
Monster-4
EcoBoost (all engine sizes)
Jun 4, 2012 11:36 PM
EASTSIDEAUTO
Feb 19, 2012 01:45 AM
scl009
Feb 18, 2010 04:52 PM
