Tach hook up on EEC IV
Old Oct 14, 2007 | 07:39 AM
wayneF250's Avatar
wayneF250
my truck dont have a Tach, So how do u hook up a tach on these fuel injection trucks,?
Old Oct 14, 2007 | 08:13 AM
Linemo's Avatar
Linemo
what year truck is it? If it were me I would go to a wrecking yard and find the same year truck with a tach and get the instrument panel off of it and swap I know the 92-96 will work plug and play with the same year model !!
Old Oct 14, 2007 | 09:38 AM
92F150Flare's Avatar
92F150Flare
Tach hooks to the coil and ground.......and a 12v wire for your light. Directions in the tach should tell you where.
Linemo is right about the swap......very easy to change the cluster......here's the info.......
https://www.ford-trucks.com/article/...Or_Bronco.html
Make sure you get the right year to do it......."Lost in90's" has some for sale in the classifieds.
Good Luck
Bob
Old Oct 14, 2007 | 10:11 AM
F150xlt's Avatar
F150xlt
If you look at the terminals at the coil one will have a red/light green that's 12 volts for the coil.
The other terminal will have a tan/yellow wire. The tan/yellow wire is the one you want to splice into or attach a new wire to the same terminal for your aftermarket tach.
Old Oct 14, 2007 | 08:13 PM
92mnfordtrk's Avatar
92mnfordtrk
I have a 92 F150 (dead) with a tach in the gauge cluster. Can I switch this into my new 94 F150 w/out Tach? Or is the airbag the problem? Sorry to hijack your thread waynef250. Thx.
Old Oct 14, 2007 | 08:49 PM
tomtoc's Avatar
tomtoc
another vote for doing the tach swap. i was looking at adding an aftermarket one myself before i realized you could do this. i'm a terrible mechanic and can do the tach swap in about 15 minutes once you get the right year/part
Speedymaru
73
Nov 29, 2023 05:24 PM
misleib
1978 - 1996 Big Bronco
Aug 24, 2015 10:22 AM
GB SISSON
General Diesel Discussion
May 14, 2013 06:31 PM
03trueblue
Aug 26, 2012 09:30 AM
speed demon
Jun 29, 2008 01:17 AM
