check engine light from hell
Old Jun 21, 2008 | 01:13 PM
Texan58's Avatar
Texan58
i guess you can tell my mood by the title of this post...
1993 F-150 5.0L 218,000 miles
check engine light is on. Code is saying EGR valve. I replaced the EGR valve ($160.00), and also the EGR Position Sensor ($32.00)
i replaced both O2 sensors about year ago as well as BOTH catalytic converters.
and that light is STILL on...
can anyone give me some advice before I reach up in there and unplug it?
the only clue to a possible problem is a strong unburned gas smell when it starts up. other than that, is runs great.
Old Jun 21, 2008 | 01:58 PM
quicklook2's Avatar
quicklook2
did you reset the computer?
Old Jun 21, 2008 | 02:38 PM
Lazy K's Avatar
Lazy K
What code are you getting?
Old Jun 22, 2008 | 07:00 AM
Texan58's Avatar
Texan58
No clue what the code was. I took the truck to a shop and was told the code indicated the EGR valve. They didn't replace the parts, I did.
Nope, didn't reset the computer...how do I do that?
Old Jun 22, 2008 | 09:35 AM
quicklook2's Avatar
quicklook2
disconnect the neg battery cable for 20 minutes.
drive truck around after for it to relearn.
next time have the shop print out or write down the codes or read them yourself.
Old Jun 22, 2008 | 11:22 AM
khadma's Avatar
khadma
Carpenter Local 745
Just a QL2 just said, all those parts need a computer reset.
Also, the light may need to cleared with a scanner .
Old Jun 22, 2008 | 01:46 PM
danr1's Avatar
danr1
<i>No clue what the code was. I took the truck to a shop and was told the code indicated the EGR valve. They didn't replace the parts, I did. </i>
Not that easy, the error codes are not that "cut and dried", the computer indicates the problem is in the EGR system but doesn't say exactly what the problem is as you are probably now aware.
Could be the valve, could be the control, could be the vac line to the control or valve and it could be the sensor that reports the valves position to the computer or a combination of any of the above. Only testing will show the true cause of the problem.
If the shop lead you to believe otherwise they were mistaken.
Old Jun 23, 2008 | 07:55 AM
alxsnmr's Avatar
alxsnmr
The old OBDI system only requires the neg cable removed to clear the code. OBDII which is roughly late 95 and on just requires a scanner. Either pick up a code scanner from the autoparts store and learn to use it, or visit fordfuelinjection.com and learn the 'paper-clip' method of pulling your codes from OBDI.
Old Jun 23, 2008 | 08:15 AM
Texan58's Avatar
Texan58
Thanks to everyone. I will reset the computer and let you know what happens.
Old Jun 23, 2008 | 09:33 AM
Dre82s's Avatar
Dre82s
Check engine light form the boomdox or bellow!
So I have this dilema, my check engine light come on while I'm driving but the code scanner does not pick it up. once the engine shuts off the code get erased what the f is that anyone can help me can I run the scanner while the truck is on?
Old Jun 23, 2008 | 04:43 PM
EPNCSU2006's Avatar
EPNCSU2006
It sounds like something is wrong if the computer is not storing the codes in memory after you turn off the engine.
techsuphunt
Escape & Escape Hybrid
May 1, 2008 10:28 PM
timbo65
22
Aug 18, 2007 01:15 PM
X-Power
Sep 15, 2006 07:20 PM
Keith460
Jan 15, 2001 01:35 PM
Rodriguez
Jul 31, 1999 05:07 AM
