94 Explorer with code 332/ EGR failure
Old Jan 14, 2001 | 07:13 PM
Keith460's Avatar
Keith460
I've had a code 332,EGR valve opening not detected, for sometime and cannot find the cause. I have replaced both a sensor, the one with the two hoses to the exhaust manifold, and a solenoid for the EGR valve. Removed and cleaned the EGR valve and Intake manifold ports and vacuum tested the EGR valve to insure that it is working. Cleared codes several times but still the check engine light comes back on intermittently with the same code stored in memory.
Anybody have any ideas what else would trigger this code?
Kind regards, Keith
Old Jan 15, 2001 | 05:55 AM
PaulL1's Avatar
PaulL1
Check and see if either of the 2 hoses going to the DPFE sensor are clogged. They are usally clogged with a white hard substance. This is common and can usually be cleaned with a little gum cutter and some shop air blown through it.
Old Jan 15, 2001 | 11:27 AM
joelb's Avatar
joelb
I concur ... the DPFE sensor is often the culprit in unexplained EGR problems. There are some simple multi-meter tests that can be done to get a ball-park idea of whether or not the DPFE sensor is operating correctly. Unfortunately, it's been a while since I've done this and I can't remember the specifics of the test. Search the threads and the procedure may be found in an earlier post. If I can remember what to do I'll repost.
Good luck
Old Jan 15, 2001 | 11:34 AM
joelb's Avatar
joelb
Ooops, just noticed that from you post it sounds like you've replaced the DPFE sensor already. Take the other guy's advice and clean the hoses to the DPFE. Also, check the hoses for any kinks or unnecessary tight bends. That can throw off the sensor readings as well.
Old Jan 15, 2001 | 01:11 PM
Keith460's Avatar
Keith460
Yes I have replaced the DPFE sensor and the two rubber hoses. I also used compressed air to blow out the metal tubes from the exhaust manifold as well. When the engine is running, their is definitely air pressure coming out of the tubes and hoses. I just cleared the codes today but code 332 still comes back and haunts me.
Old Jan 15, 2001 | 01:35 PM
swyllie's Avatar
swyllie
Fordfr4x4
Mar 13, 2013 04:53 PM
traumadog29
1983 - 2012 Ranger & B-Series
Aug 21, 2006 05:15 PM
cablemaster
Sep 20, 2004 05:24 PM
poknox
Jun 3, 2004 07:10 PM
opie1938
Feb 23, 2004 02:50 PM
