Bucking on acceleration?
Old Sep 13, 2006 | 06:34 PM
X-Power's Avatar
X-Power
I have 144,000 on my vehicle. The spark plugs are the Motorcraft Platinum ones and where changed about a year ago, the wires are original. Fuel system is clean and air filter, EGR valve and EGR pressure sensor are new.
For some reason certain times when I put the pedal down the car goes to downshift but doesn't hook up, it starts bucking violently instead until you take your foot off the gas. On other occassions it does not seem to occur.
I have had a check engine light for about 3 months that says the EGR is clogged. I just recently replaced all components of the EGR system including Valve, BPFE sensor, EGR Tube and hoses- but the light is still on.
What else could this be?
Help would be greatly appreciated.
Old Sep 13, 2006 | 07:58 PM
danr1's Avatar
danr1
When my truck did that it was time for a tune up. New rotor, cap, wires and plugs cured the problem.
You don't want my opinion of those platinum plugs. lol
Old Sep 13, 2006 | 09:06 PM
X-Power's Avatar
X-Power
Thanks, my mechanic suggested that as well.
Wonder why the EGR code keeps coming up?
Old Sep 14, 2006 | 12:18 PM
marragtop's Avatar
marragtop
Also, did you reset the codes when you replaced the EGR?
Old Sep 14, 2006 | 01:21 PM
danr1's Avatar
danr1
The excess unburned gas from the need of a tune up could be triggering a EGR code.
Old Sep 14, 2006 | 01:25 PM
danr1's Avatar
danr1
Wanted to add,
You will need to change to oil after the tune up also, the oil may/will be contaminated with unburned fuel if it ran bad enough and cause “code” problems, (do this before clearing the codes).
Old Sep 14, 2006 | 08:44 PM
X-Power's Avatar
X-Power
Ok, I will change the oil.
Don't know if I need to reset the codes as the battery was disconected when I installed the pressure feedback sensor.
Is disconnecting the battery the best way to reset the codes?
The light was off for about 30mi after I hooked everything back up then it came back on.
Old Sep 15, 2006 | 04:59 AM
marragtop's Avatar
marragtop
Disconnecting the battery will reset the codes.
Old Sep 15, 2006 | 07:20 PM
Mic_bug's Avatar
Mic_bug
Ditto that!
Al_Cuevas
1997 - 2003 F150
93
Aug 13, 2016 08:50 AM
MIKE138
Mar 10, 2016 01:46 AM
cjharvey2000
Mar 8, 2016 10:06 PM
Justin's Green Truck
1997 - 2003 F150
Jan 23, 2011 08:20 AM
teezy
May 20, 2010 01:03 PM
