Aod
Old Jun 23, 2008 | 02:08 PM
currituckF150's Avatar
currituckF150
Aod
It is possible to have a AOD tranny rebuilt to be as strong or stronger than an E4OD? Any idea for how much $$, ballpark?
Old Jun 23, 2008 | 02:34 PM
Conanski's Avatar
Conanski
These guys seem to think so..
Ford-AOD.com the ultimate AOD Transmission Perfromance Website
Old Jun 23, 2008 | 02:56 PM
currituckF150
Paul, the reason I ask is I can get a truck for parts that has an AOD in it & was thinking that a mass air conversion is easier. Does your AOD hold up ok as far as towing, performance, etc?
Old Jun 23, 2008 | 03:12 PM
Conanski's Avatar
Conanski
My AOD has done everything I have asked it to do for 8 years behind this warmed up 5.8, and all it has is a shift kit. Now I don't do any heavy towing.. nothing larger than a couple sleds on a trailer or a yard of dirt in the bed, but I don't baby this thing either, it's hard to stay out of it when it works as well as it does. If the truck you get is a later version then the tranny will have the internal updates that occured over the years, and if it's in good working order it should last just fine with the addition of a shift kit. Of course you could have it rebuilt up to whatever spec you want and then you know what you got.
Old Jun 23, 2008 | 03:17 PM
85e150's Avatar
85e150
Seems like the '88-'93 ones + a beef up are the way to go. In addition to the site above, more sites with info/propaganda/parts/transmissions:
AOD Performance Products - Baumann Electronic Controls
www.CKPerformance.com
TCI - Ford AOD, AODE and 4R70W
As for price, TCI quotes around $2000 for a beefed AOD. You can see their quotes on the site above. Makes you gasp after you look at a beefed C6 for $1200....
Old Jun 23, 2008 | 03:21 PM
currituckF150
The truck I'm looking @ is an early 93, but like you say I'll rebuild it w/ a shift kit & it will be good to go. I will need the TV cable from the parts truck, crossmember & driveshaft, right? Anything else?
Old Jun 23, 2008 | 04:51 PM
Conanski's Avatar
Conanski
Yeah... take the plate that all the cables attach to on top of the intake.
